ORIGNIAL 440 SIXPACK ENGINES SPECS...
#128721
09/27/08 05:33 PM
09/27/08 05:33 PM
Posts: 164 CH
plyrr69
CH
Hello together
I search pictures an details from the stock sixpackengines, shortblock assembly. Does anybody has pictures of original shortblocks, maybe with a piston on the top position. Does anybody measured the distance from the top piston position to the blocks deck height?
Tx for answer...
David
___________________________
.......plymouth tells it like it is...!
Re: ORIGNIAL 440 SIXPACK ENGINES SPECS...
[Re: DaytonaTurbo]
#128725
09/28/08 12:58 AM
09/28/08 12:58 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
69 and 70 had different pistons. Which exact year?
They also had different connecting rods.....And crankshafts....And harmonic balancers....And...
[Re: 1_WILD_RT]
#128726
09/28/08 03:21 AM
09/28/08 03:21 AM
DaytonaTurbo
Manitoba, Canada
All of which would not be likely to show up on a pic of the short block. His post was mainly asking about pistons...
[Re: DaytonaTurbo]
#128727
09/28/08 03:42 AM
09/28/08 03:42 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The Balancer is obvious from twenty feet...The rods are obvious if the pan is off...
[Re: DaytonaTurbo]
#128728
09/28/08 03:43 AM
09/28/08 03:43 AM
Posts: 164 CH
plyrr69
CH
I have a Sixpack 69 1/2 and the friend of mine got a 70, thats why both are interesting for us. The most important point is: how do they come on a C/R 10.5:1...
[Re: sixbbl69]
#128730
09/28/08 08:45 AM
09/28/08 08:45 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
at least you have the better of the 2 engines.the 69 sixpack is faster and lighter.i think the 70 intake is heavier then the whole 69 engine. the 70 sixpack and the hemi is what dragged these cars down.more for looks then speed and performance.
[Re: plyrr69]
#128731
09/28/08 11:42 AM
09/28/08 11:42 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
That's the RATED compression ratio they weren't actually that high .
[Re: plyrr69]
#128732
09/28/08 12:07 PM
09/28/08 12:07 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
69 1/2 is rated 10.2:1,70 is rated 10.5:1.Different pistons with valve reliefs.
[Re: plyrr69]
#128734
09/28/08 07:29 PM
09/28/08 07:29 PM
JohnRR
U.S.S.A.
where is this information from, do you have pistonpics?
70 the piston is a flat top and has 4 valves reliefs , it should be about .020 below the deck
69 is a flat top NO VALVE reliefs and will be about .040 below the deck
[Re: JohnRR]
#128735
09/30/08 12:43 AM
09/30/08 12:43 AM
Posts: 164 CH
plyrr69
CH
Very interesting, anyone got pics?
[Re: plyrr69]
#128736
09/30/08 09:45 AM
09/30/08 09:45 AM
JohnRR
U.S.S.A.
I don't mean to be a stick in the mud but have you never seen a flat top piston ???
Here , I heisted this from another thread , it's not an original piston but this is what a 70-71 6pk piston looks like , the 69 piston is the same WITHOUT the 4 notches ...
the picture is too big to put in the post , click the link
https://board.moparts.org/ubbthreads/upload2/4716100-Pistons.jpg
Oh and just so you know , there is NO direct replacement available for the 69 engine , at least nothing that is shelf stock anywhere. Most people use the 70 -71 piston and it puts the piston where it would be for factory 69 NHRA blueprint spec , but thats not correct as the factory built them so you will have to get a custom if you want to mimic the factory build .
[Re: JohnRR]
#128737
09/30/08 11:03 AM
09/30/08 11:03 AM
Posts: 164 CH
plyrr69
CH
Hello John...
No, not an Original Sixpack... and i want to see the Deckclearance to see if we are making a calculation error, or if there are that much differences... It looks like there are either wrong informations about the C/R or there is an error our calculation....
And if i do my engine it has to look and be as original as possible...
tx dave
ps i have a 108 piston in my block!!! But this is an R/T block..
[Re: plyrr69]
#128738
09/30/08 12:26 PM
09/30/08 12:26 PM
JohnRR
U.S.S.A.
third piston from the right is at TDC , thats about .020 in the hole . this confuses me , maybe something in your translation ??? Quote:
are you saying your piston is .108 BELOW the deck ? if so it's because you have the wrong piston , probably is the part number 2266 on it?
Also an R/T block ???? There is NOTHING SPECIAL about a 6pk block vs. any other 440 block of the same era other than what is stamped on it .
[Re: JohnRR]
#128739
09/30/08 02:06 PM
09/30/08 02:06 PM
Posts: 164 CH
plyrr69
CH
Sorry, i didn't write correct...
This is all what my piston is... 2853108
