Re: no st box brace OR motor mount-will i die?
[Re: Winchester 73]
#1287198
08/18/12 12:20 PM
08/18/12 12:20 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
no brace on steering box on my dart and it has elephant ears for motor mounts.i hear all you guys talking about steering mounts flexing and such but most of you guys probly have a 600 lb chunk of iorn pressed against your steering box and i dont so will i die?and my next question is wouldent solid motor mounts make steering better on some of your cars?
Interesting concept: Solid engine mounts reinforcing the K-member. Worth some investigating!
I know that when XV was engineering their stuff, they learned the the engine on rubber mounts actually made ride quality worse -- the engine would continue to bounce some after the car hit a bump.
Rick
[Re: Rick_Ehrenberg]
#1287199
08/18/12 03:51 PM
08/18/12 03:51 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
It would probably take a little bit of triangulation to really steady the engine in the chassis. 3/8" plate steel will only do so much when it comes to stopping a heavy chunk of iron from wobbling around. The rubber trans mount will allow plenty of slop.
#1287201
08/19/12 11:46 PM
08/19/12 11:46 PM
Posts: 168 Washington State, USA
Winchester 73
i had a 440 in a street duster mounted with an eng plate and it shook at idle(cool )but it did always seem to me to ride great .
meybe the motor bouncing up and down on the rubber biscuits is whats failing k frames?
engines glued into the engine bay like mother mopar did is the type of thing i wish chevy did so i could make fun of it!
Rick
[Re: Winchester 73]
#1287202
08/20/12 12:29 AM
08/20/12 12:29 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Show me all of these FAILED K-members. Most are from mistreatment or external things like rust.
I have broke a K-member. Just the LCA mount welds. It was 125% my fault. I overloaded the car way way beyond is GVWR, lowered the car, and didn't run bumpstop bushings.
?? And Chevy's don't have rubber motor mounts??
They've got the same thing.
[Re: autoxcuda]
#1287203
08/20/12 05:02 PM
08/20/12 05:02 PM
Winchester 73
http://www.bobschevelleparts.com/images/T/160293.jpg
heres a link to some 69/70 chevy mounts.notice the hooks of metal on the bottoms.junkyard guys no you dont have to remove motor mounts on a mopar to pull the engine-cut exaust and lift!not so with chevy or ford all the way back to the 40S
[Re: Winchester 73]
#1287204
08/21/12 03:07 AM
08/21/12 03:07 AM
autoxcuda
So Cal
Not on a 73-76 A-body or 72 up B-body.
What about the mid sixes Nova that motor mounts would break and the car would accelerate forward? GM had to put straps to tie down the motors.
The A-body GM mounts have a fail safe interlock. That just takes over after the rest of the mount has completely failed.
[Re: autoxcuda]
#1287205
08/21/12 09:55 PM
08/21/12 09:55 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
Easy answer, you were born you will die eventually. Will you die because of the steering box not being braced or motor mount...I doubt it. In my younger years I even hacked up the K member more than it is from the factory and whacked some of the steering box mount and the 440 was mounted with elephant ears. I drove the car on the street and I am typing this today. Car was on them skinny front runners and some large slicks and it had no problem driving on the street in the rain with no wipers either. Granted I do things differently 20 years later....
[Re: jcc]
#1287209
08/24/12 10:54 PM
08/24/12 10:54 PM
PHJ426
Fly Over States
In the passing years, my forte seems to be inane sophomoric quips, or so they tell me.
Nothing wrong with that.
