Re: any1 jyd scource alum calipers?
[Re: astjp2]
#1286118
08/16/12 01:51 PM
08/16/12 01:51 PM
Posts: 661 Iowa
jon01
Iowa
I think Panther calipers are aluminum - the ones on my Marauder are... They might be OK for an a-body but I wouldn't want them on anything heavier, they were certainly marginal on my car prior to all of the mods.
94+ Mustang Cobra stuff can usually be had for ~$300, calipers, pads and rotors. Easy and cheap to find parts for.
68 Charger R/T - #'s matching car, 499/727/3.91
[Re: 1_WILD_RT]
#1286120
08/16/12 02:02 PM
08/16/12 02:02 PM
Posts: 661 Iowa
jon01
Iowa
Yep, saw that. Can they easily be adapted? I know older Mustang stuff can be but unsure on 05+ cars.
[Re: Winchester 73]
#1286121
08/16/12 02:07 PM
08/16/12 02:07 PM
Posts: 31,052 Oregon
AndyF
so ill be putting a roadraceish a body on the cheap and was thinking about scrounging around the junkyard for some alum calipers to save whieght and possibly get some more piston area.then make my own alum brackets.
anyone else do this or benchrace it around in thier brains?
That was the whole point of my Wilwood kit. AR000 is the part number. It is a pair of brackets that let you bolt on the lightweight Wilwood calipers to a set of 11.75 rotors.
[Re: AndyF]
#1286122
08/16/12 05:06 PM
08/16/12 05:06 PM
Posts: 168 Washington State, USA
Winchester 73
exactly what i was thinking of minus the expensive calipers.im tryin to find some thing alum in design but with a generic enuff mount to make an adapter and use my cordoba rotors
[Re: 1_WILD_RT]
#1286128
08/17/12 05:58 AM
08/17/12 05:58 AM
Posts: 75 Lakeland, FL
sixpakchallenger
Lakeland, FL
I have a spare set of those calipers from when I upgraded my 07 GT Vert. I never thought of using them on my Challenger which already has 11.75 rotors.
The calipers are pretty light at 4.9 lbs each (without the adapters). The adapters wiegh in at 3.8 lbs. They are metric and designed around a 30mm thick disc so spacers would be needed for the thinner 11.75 disc. The piston diameter is 41.5mm.
I don't have a spare 11.75 rotor and spindle to try a mock-up on, but I bet it's alot harder than it looks to adapt these.
2007 Mustang GT Vert 2004 Ram 2500 QC 4X4 1971 Challenger Vert 5.7 Hemi Project
[Re: AndyF]
#1286130
08/18/12 02:16 AM
08/18/12 02:16 AM
Winchester 73
so those calipers arent as good as stock ones? to tell the truth i was thinking of getting something from a truck.i saw a caliper on a 3/4 ton ford van that looked alum and was freakin huge!like a mans foot they looked alum but they maybe were painted by the factory or coated or something.i know i said i was looking for a lbs reduction but im really looking for something definately not heavier and way bigger IE:aluminum.ill hit the jyd next week and let you guys know.
[Re: Winchester 73]
#1286131
08/18/12 03:09 AM
08/18/12 03:09 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
41.5 mm piston size would result in a 30% decrease in front brake force.
Actually they are 43mm which has an effective area of 2900 sq/cm... But the Viper uses a staggered piston configuration 44/40mm which gives an area of 2775 sq/cm... So it doesn't sound like the Viper calipers are as good a choice as the Mustang caliper...
The stock A body 2.6" single piston has an area of 3420 sq/cm
However using dual pistons applies a more even loading to the brake pads & in fact the surface area of the pads is greater, plus as I mentioned in an earlier post there is good aftermarket performance support as far as pad material..... Without doing a bunch of research I can't give any kind of accurate numbers but between bigger rotors with their greater leverage, larger more aggressive brake pads which are more evenly loaded.... You wind up with greater braking force that can be modulated more effectively...
[Re: DoctorDiff]
#1286134
08/19/12 12:57 AM
08/19/12 12:57 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I agree the Mustang calipers have less clamping force than the stock single piston calipers, my point is Andy suggests thats a problem while using the Viper calipers for his conversion which have even less clamping force...
And yes there are performance brake pad options for the Mopar caliper but not as many or as cheap as the options available for the Mustang calipers...
