M/T ET street radial ? #1285827
08/15/12 04:57 PM
08/15/12 04:57 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Anybody using these like them ? Wondering how good they hook compared to the Hoosier radial slicks I use. I am looking at a set thats 29.6 tall x 10 wide. I want to stay with the radial tire as I like the way they handle on the street better then the bias tires. I really want a taller tire but everything taller gets to wide for my stock wheelwell. Ron
Re: M/T ET street radial ? [Re: 383man] #1285828
08/15/12 05:08 PM
08/15/12 05:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ron, I had them on my old 340 72 swinger. They ride nice and hooked just fine but that car was slow (13.82)... They have a decent amount of tread so unless it's pouring you can still make it home ok.
Coming soon!!!!
Re: M/T ET street radial ? [Re: Mr.Yuck] #1285829
08/15/12 05:10 PM
08/15/12 05:10 PM
Renton Washington
Triple Threat Offline
Renton Washington
I think you'll like them
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: M/T ET street radial ? [Re: 383man] #1285830
08/15/12 05:43 PM
08/15/12 05:43 PM
an8sec70cuda Offline
I run the 295-65 M/T ET Street radials. I've been 1.320 sixty foot w/ them.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M/T ET street radial ? [Re: an8sec70cuda] #1285831
08/15/12 06:53 PM
08/15/12 06:53 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Ron,
are you looking at the et street radial(DOT street legal) or radial slick ?like the hoosier.
i have used the et street radial for a number of years and been happy though they are sensitive to track prep.they are great on the street just don't go crazy in the wet ,though i have never had issues.
i used the 275/60R15,several friends have used the 295/65R15 all with good results
they are a BIG heavy tyre.for some reason they are too close to the dogleg on my Plymouth yet they fit fine on a mates 69 Roadrunner.yet i can fit the Hoosier 9.0x30R15 radial slick.go figure
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: M/T ET street radial ? [Re: tex013] #1285832
08/16/12 01:15 AM
08/16/12 01:15 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
They work well on my car. I run smaller ones (255/60's) and they pretty much dead-hook my car, which has been 1.55 60's. You do a lot of street driving though, Ron. And they are VERY soft. Notoriously short on street life expectancy.
Re: M/T ET street radial ? [Re: StealthWedge67] #1285833
08/16/12 01:47 AM
08/16/12 01:47 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Ron,
I have 295/65/15 ets on my car. They are basically 29.5 inches tall.
After some chassis changes they are dead hooking with the mild motor. They are hooking so hard they exposed major issues in the acc pump circuit that I didnt know existed.
I was running 275/60/15 Et. They hooked decent with the 11.3x motor. But, with the chassis changes I have made, I think they would hook very well now.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: M/T ET street radial ? [Re: 383man] #1285834
08/16/12 09:28 AM
08/16/12 09:28 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ron....I have 325/50s on my Dart and have no complaints on the street. At the strip if the track is good they're great, if the track is marginal they suck. I have been 1.38 60' on a good track though.
Re: M/T ET street radial ? [Re: justinp61] #1285835
08/16/12 10:26 AM
08/16/12 10:26 AM
Ma
Voluster Offline
Voluster  Offline
Ma
I use the 275 pro ET radial and almost put the car on the bumper 3 pass
1.361 60ft at 3470 lbs
Re: M/T ET street radial ? [Re: Voluster] #1285836
08/16/12 10:33 AM
08/16/12 10:33 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
you are already using a radial slick, so tuning is similar....
295-65 MT you cant go wrong, they will last pretty well as a street tire and obviously work very well on the track...295 Hoosier is a little lighter and will wear out a lil faster with street driving, I have been just as fast on both tires
....BAD A$$ STREET CAR.....
Re: M/T ET street radial ? [Re: 383man] #1285837
08/17/12 01:27 AM
08/17/12 01:27 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Hi Ron, I use the ET drag radials on my Coronet, 325x50x15's, set at 18 psi for the strip. Excellent hook, have taken pics of me off the line and they DO hook nice. I can't compare them to the Hoosier, but have heard only good things about those as well. Granted, I had to do a mini tub to get them into my wheel wells, but have plenty of room after doing so. No complaints about the M/T's at all. One thing I found out, you don't need to do a John Force burn out to get them to hook... I like that.
Best, Dave
