Cylinder head/ Intake Milling ? #1285816
08/15/12 04:21 PM
08/15/12 04:21 PM
MNobody Offline OP
MNobody  Offline OP
For every .010 off the head surface you take how much off the Intake? Thanks!
Re: Cylinder head/ Intake Milling ? [Re: MNobody] #1285817
08/15/12 04:45 PM
08/15/12 04:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Big block or small block ?
Big block is .0123.
small block is different.
Re: Cylinder head/ Intake Milling ? [Re: JohnRR] #1285818
08/15/12 08:00 PM
08/15/12 08:00 PM
MNobody Offline OP
MNobody  Offline OP
Sorry, it's a small block. Didn't know they were different.
Re: Cylinder head/ Intake Milling ? [Re: MNobody] #1285819
08/16/12 01:05 PM
08/16/12 01:05 PM
dogdays Offline
dogdays  Offline
0.0095 IIRC.
R.
Re: Cylinder head/ Intake Milling ? [Re: dogdays] #1285820
08/16/12 01:17 PM
08/16/12 01:17 PM
Texas
ChristianCuda Offline
Texas
Does the same apply to a magnum small block?
Re: Cylinder head/ Intake Milling ? [Re: ChristianCuda] #1285821
08/16/12 04:27 PM
08/16/12 04:27 PM
dogdays Offline
dogdays  Offline
Well the intakes are the same except for the bolt hole angle, so yes.
R.
Re: Cylinder head/ Intake Milling ? [Re: MNobody] #1285822
08/16/12 04:40 PM
08/16/12 04:40 PM
If with your choice of head & intake gaskets the intake to head port/bolt hole alignment is acceptable to you as is then yes follow the .0095 per .010" rule & if not I'd set the heads on the head gaskets/block & lightly snug several head bolts then mockup the intake & its' gaskets & see how far off you are on the slope & take that figure to your machinist and LA/magnums have a different intake face angle (7 deg). Not sure how much the respective 7 deg difference makes when figuring the slope angle metal amt to be milled but tell him which one you are dealing with
Re: Cylinder head/ Intake Milling ? [Re: RapidRobert] #1285823
08/17/12 01:28 AM
08/17/12 01:28 AM
MNobody Offline OP
MNobody  Offline OP
Cool, Thanks for the info!
