Circle track engine advice #1285747
08/15/12 02:25 PM
08/15/12 02:25 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
Hello all,
I am considering building a car for the local circle tracks "Thunder Stock" class. The track is a paved 1/4 mile high banked oval, the fastest in the world they say. This class is completely filled with Chebbies, mostly Monte Carlos. Last week the fast qualifiers lap time was 13.469 seconds. I have copied and pasted the engine rules below. What do you guys think a engine good combo would be based on them? Could I build a 360 that would keep up? I know I need a properly set up car, we have another forum for that:)
10. ENGINE: Stock cast iron block, stock cast cyl heads and stock cast iron intake manifold are required. All engine parts must remain in their original “as cast” configuration. ANY modifications are illegal. Maximum displacement for Ford and Chevrolet engines is 360 cubic inches and 366 cubic inches for Mopar. Ford engines must be 351 Windsor block and cyl heads. Carburetor must be as installed by the manufacturer on the baseline model for said manufacturer (One 4bbl max, no aftermarket carbs) factory snorkel type air cleaner or 14" X 4" after market air cleaner with solid steel top and bottom. NO flow control designs and NO high flow elements will be allowed. Engine must be in stock location. Stock steel or rubber mounts are ok. One engine movement limiter is allowed (cable, chain or rod) HEADS: No aftermarket, bowtie, vortec/ swirl port or SB chevy angle plug heads are allowed. Valve lift is limited to .420 on SB chev and .450 on Ford or Mopar engines. Rocker arms must retain stock ratio (1.5 on SB chev ) NO aftermarket or roller type rocker arms are allowed. Engine compression is limited to 150 lbs ( 5 revolutions ) ZERO tolerance. OEM replacement pistons are allowed, symmetrical with 4 reliefs or dished with 5/64 - 5/64 - 3/16-ring sizes. Crankshaft must match block and model/year of car (weight/measurements). Crank will be teched. Powder coated connecting rods are not allowed.
11. Exhaust: Complete leak free, tight exhaust system with a maximum diameter of 2.25" OD must be run from the engine to an area behind the driver and must incorporate (1 or 2 depending on system) approved mufflers. No “H” pipes. Stock “Y” pipe allowed, no other 2 into 1 systems. NO center dump exhaust manifolds. Approved mufflers ONLY. 88-Decibel Limit.
(Mufflers that can be used: Napa 17713 or 17714. Dynomax and walker 17731 or 17732).
Thanks for any replies!!
Re: Circle track engine advice [Re: MadMez] #1285748
08/15/12 02:38 PM
08/15/12 02:38 PM
You need to post the car limits, IE what stock size bodys allowed and which years A 1974 Duster or a 1977 Volare with a 360 should smoke the Monte Carlo
Re: Circle track engine advice [Re: Cab_Burge] #1285749
08/15/12 02:45 PM
08/15/12 02:45 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
Mr. Cab
Here are the allowed cars.
2. 1965 and newer American made passenger cars, no convertibles. 108" minimum wheelbase. Minimum weight 3200 lbs with driver in car. 56% maximum left side weight.
Re: Circle track engine advice [Re: MadMez] #1285750
08/15/12 02:49 PM
08/15/12 02:49 PM
Oh Baby, that leaves the door wide open. Time to whoop some Fords and Chevy butts 1965 or 1966 Dart, Valient or Barracuda If not one of them then look for a 1970 to 1972 Duster
Re: Circle track engine advice [Re: Cab_Burge] #1285751
08/15/12 03:40 PM
08/15/12 03:40 PM
The Great White North
RAMM Offline
RAMM  Offline
No powder coated rods!! Forget it. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Circle track engine advice [Re: RAMM] #1285752
08/15/12 03:50 PM
08/15/12 03:50 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Maybe they meant NO CAPPOOOWWWWderd metal rods.LOL With those rules I'd say go for it.
Re: Circle track engine advice [Re: goldmember] #1285753
08/15/12 04:13 PM
08/15/12 04:13 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
What cam is allowed, Solid roller? Doesn't say you can't! 273 adjustable rockers sound like they are in play here.
Does the block have to be the same year as your car.
74-76 Duster/Dart Sport might be a good choice. As mentioned the Volare/Aspen too.
Re: Circle track engine advice [Re: RobX4406] #1285754
08/15/12 04:44 PM
08/15/12 04:44 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
i run circle track on dirt,the best place to start on a engine is dave hughes @ hughes engines, hell do you a great job, that would be the 1st guy i'd call,later jg309
Re: Circle track engine advice [Re: jg309] #1285755
08/15/12 07:01 PM
08/15/12 07:01 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
go straight turn left.
Re: Circle track engine advice [Re: ro23car] #1285756
08/15/12 07:52 PM
08/15/12 07:52 PM
Mash Throttle, spin tires, turn left, go straight Let off before turn, straighten wheels and go around the corner do it again and again HEE HAWW Lots of fun, if you can do it
Re: Circle track engine advice [Re: Cab_Burge] #1285757
08/15/12 08:09 PM
08/15/12 08:09 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
It would be nice to see the chassis rules. Though the Aspen/Volare would make a good car, you are limited with the torsion bar set-up. A high banked 1/4 mile oval is going to take alot of bar in the right front to keep it on the track.
Re: Circle track engine advice [Re: MadMez] #1285758
08/15/12 08:35 PM
08/15/12 08:35 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Hello all,
I see you say that most of the cars are Chevs/Monte Carlos/etc... Do the rules state that you have to run the same frame as manutacturer/motor? I am not familiar with the name "thunder stock', but around here, the class has been called 'street stock' and some other names over the years. Locally, EVERYBODY runs the Chevelle, Monte Carlo, Cutlass frames,,AKA 'metric frames'. Most people run the Chev motors of course, but, I have built some Mopar engines for the same class and they ran the 'metric' frames. All tracks have different rules. I don't know about your area, but, here, the 'street stock' class is/was a tough row to hoe. You notice I said "is/was", as it has pretty well been done away with due to lack of cars. That is due to a few cars dominating the class and discouraging any new people to get involved. I can take some responsibility for that, as one customer of mine pretty well dominated the class for several years around here. Sorry,, it wasn't a Mopar, but I did co-own one for awhile that did run at the front with a Mopar motor. I helped run 'late models' in the '70's and the 'street stocks' today are better cars than the 'late models' were back then. If you can run the GM chassis, I would say you have a chance. If you have to run the Mopar chassis, you have alot of work ahead.
If you like drag racing, support your local track.
Re: Circle track engine advice [Re: Cab_Burge] #1285759
08/15/12 08:37 PM
08/15/12 08:37 PM
Slinger WI
MadMez Offline OP
MadMez  Offline OP
Slinger WI
I used to be fearless and this would not be a problem to try and do. But I am getting old now and things hurt more than they did 20 years ago!!
I started a thread in the cornering forum asking for suspension advice. I posted the suspension rules there.
Thanks guys!!!
Re: Circle track engine advice [Re: MadMez] #1285760
08/15/12 11:42 PM
08/15/12 11:42 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
not to chase you away, but moparchat.com has a separate "circle track" section with quite a few mopar racers. Lots of those guys are members here as well.
Re: Circle track engine advice [Re: J_BODY] #1285761
08/16/12 11:23 AM
08/16/12 11:23 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Jessie lackman, Rev search is his site, he is a good source of knowledge on this topic
