Carter AFB main jet #1285575
08/14/12 11:25 PM
08/14/12 11:25 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Edelbrock jets go from .077 up in size.
I need/want to try smaller jet sizes.
Anyone know where to buy?
Can I solder or fill jets I have and then drill to size?
Thanks for any input. Steve
Re: Carter AFB main jet [Re: pacifica] #1285576
08/15/12 12:04 AM
08/15/12 12:04 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
A thicker metering rod would work. That's how the system works.
Sheldon
Re: Carter AFB main jet [Re: RUNCHARGER] #1285577
08/15/12 12:07 AM
08/15/12 12:07 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I do allot of tuning on the dyno and I have never seen anything that needed to be that lean.Just saying
JAKES AUTOMOTIVE
Re: Carter AFB main jet [Re: pacifica] #1285578
08/15/12 06:27 AM
08/15/12 06:27 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I know the old D.C. manual specified smaller size for one jet while using a cross ram. I soldered one up and drilled it. Then used a larger bit to create an entrance flare for the new hole. Whether it really made a difference I don't know.
Doug
Re: Carter AFB main jet [Re: dvw] #1285579
08/15/12 08:07 AM
08/15/12 08:07 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Ok now that I know it is for a crossram them jets that need to be lean were calibrated with eguast manifolds . If you put in the smallest jet in that spot it still comes out dead on. I have dynoed with egts and did not have any rich cyl. Hope this helps. Or you can do what doug did and that works, but like I said I have had no issues.
JAKES AUTOMOTIVE
Re: Carter AFB main jet [Re: JAKE68] #1285580
08/15/12 03:28 PM
08/15/12 03:28 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I know I've got some smaller one's around, what were you looking for approx?
Russ
Re: Carter AFB main jet [Re: old_racer] #1285581
08/16/12 12:49 AM
08/16/12 12:49 AM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
Russ
Cab has what I need, but thanks just the same!!
