what cam for 450'' small block?
#1284282
08/12/12 10:41 PM
08/12/12 10:41 PM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
i have plans to build a 450'' small block using BPE 4.25'' stroke crank.
my engine currently 362'' and i need more torque to move my heavy car, 3800lbs race weight.
x block, w2's, 630 solid roller, 13.1 comp, BME alum rods, pro dominator tunnel ram with 2 650 holleys.
4.080 bore and 3.46'' stroke. i want to increase my cubic inch with BPE's 4.25'' crank.
i want to keep compression 13-13.5:1 and use my w2's. all i want to do is replace is my crank, rods, pistons and swap for BPE's kit.
will my 630 roller cam work with the added stroke?
Re: what cam for 450'' small block?
[Re: 79410aspenrt]
#1284283
08/12/12 11:09 PM
08/12/12 11:09 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
What's the duration on the cam?
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: 79410aspenrt]
#1284286
08/13/12 09:32 AM
08/13/12 09:32 AM
DragDart360
South Jersey, NJ
That cam should work good plenty of duration for a stroker
