help on tunnelram+ 2 holley carbs+Lokar cable mount??? #1284027
08/12/12 12:40 PM
08/12/12 12:40 PM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
Well i put a post on here awhile back about putting two Holley carbs on my wieand tunnel-ram that are mounted sideways, with the wieand tunnel ram linkage.No my question is what did you guys use to hook up your throttle cable to the tunnel-ram linkage? i mean did you use the factory cable hold down assembly or did you modified it etc?? All i have right now is the lokar throttle cable and mount that is not going to work.also would like to see some pics of yours if you could post some pics please.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: help on tunnelram+ 2 holley carbs+Lokar cable mount??? [Re: mopar65] #1284028
08/12/12 01:01 PM
08/12/12 01:01 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I used the factory mounting bracket for the cable. I also used a Lokar cable. I will attach a picture. Hopefully you will be able to see it. I did drill through the end to run the allen bolt through to the linkage. You will have to do some "custom" work.
Re: help on tunnelram+ 2 holley carbs+Lokar cable mount??? [Re: 70HemiGTX] #1284029
08/12/12 01:28 PM
08/12/12 01:28 PM
mopar65 Offline OP
mopar65  Offline OP
cool thanks fort he info that what i was looking for. also on the mount can i use one from a small block or is it big block only? i ask this because i know wear there are some small block ones but will have to look more for a big block one.but thanks again off to look for a factory throttle cable mount. thanks Mopar65
P.S. oh one more question wear did you get your throttle return springs at? i mean parts store etc?
Re: help on tunnelram+ 2 holley carbs+Lokar cable mount??? [Re: mopar65] #1284030
08/12/12 01:32 PM
08/12/12 01:32 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Bobby, stop by the shop. I have a couple for throttle brackets laying on the bench. You might be able to use one for what you need.
Jason
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: help on tunnelram+ 2 holley carbs+Lokar cable mount??? [Re: 71yelladustr] #1284031
08/12/12 04:06 PM
08/12/12 04:06 PM
mopar65 Offline OP
mopar65  Offline OP
Jason
Thanks very much Jason that is very kind of you. I will stop by tomorrow after work.Thanks again Bobby
Re: help on tunnelram+ 2 holley carbs+Lokar cable mount??? [Re: mopar65] #1284032
08/13/12 10:42 AM
08/13/12 10:42 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
It's an old big block bracket. The springs are just Mr. Gasket or something like that off the shelf.
