Re: s.b stroker kits???
[Re: jp15]
#1283909
08/12/12 11:05 AM
08/12/12 11:05 AM
Posts: 7,506 Az
Crizila
Az
Did you try Hughes engines?
Fastest 300
[Re: jp15]
#1283912
08/12/12 12:14 PM
08/12/12 12:14 PM
Posts: 31,085 Oregon
AndyF
Parts come an go depending on demand. I built a 427 inch small block using a 4.125 crank a couple of years ago. There is a series of articles on my website about that engine build. www.arengineering.com then click on tech articles. Should be plenty of pictures as well as vendor contact information for you.
[Re: AndyF]
#1283913
08/12/12 05:59 PM
08/12/12 05:59 PM
Posts: 1,532 off the grid
340B5
off the grid
I chased my tail trying to find the "perfect" kit. It seems by time you get all the upgrades; forged crank, forged pistons etc. it is about the same price to piece it together.
Yeah, it's got a smallblock.
[Re: 340B5]
#1283914
08/12/12 07:59 PM
08/12/12 07:59 PM
Triple Threat
Renton Washington
Call Rod Bloomer, Owner of BPE, you wont be sorry.
I have one of his cranks in my small block stroker, awesome piece for the money.
[Re: Racebuddy]
#1283917
08/14/12 09:01 PM
08/14/12 09:01 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
I am very happy with my BPE crank. I already had a set of rods and I needed custom pistons anyway for .350 deep valve reliefs and a dish to keep the compression to around 12.5 with my 47cc small chamber W5's so a kit was not what I wanted. It all works out to about the same though just a little cheaper if you can use an off the shelf piston.
