Difference between 10.5 and 11.0 cr #1283126
08/10/12 05:35 PM
08/10/12 05:35 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Hey...!
My 408 has 10.5:1 cr...my 60ft is 1.47...
I wonder if I could notice any difference in performance if I step up to thinner heads gasket and get 11.0:1 cr ?
Speculate on that please
Dan
67 Barracuda
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283127
08/10/12 06:40 PM
08/10/12 06:40 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
You will notice a difference with a 1/2 point jump in comp.
On my old 440 906 I saw 2 tenths with a .040 shave or about .7 comp jump.
With your little 408 you will see less, but you will still see a gain.
Re: Difference between 10.5 and 11.0 cr [Re: Sport440] #1283128
08/10/12 07:10 PM
08/10/12 07:10 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It is well documented that the power difference regarding compression will be larger with lower compression to start with.
In other words, you would gain more power going from 9 to 1 to 10 to 1 than you would going from 13 to 1 to 14 to 1.
Hope that makes sense.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283129
08/10/12 07:47 PM
08/10/12 07:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A difference in heads will be a factor also... alum
heads may see a bigger benefit due to alum heads like
more compression to equal out to iron
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283130
08/10/12 08:02 PM
08/10/12 08:02 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Hey...!
Dan
67 Barracuda
Very little difference. Less than 10 HP.
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283131
08/10/12 08:37 PM
08/10/12 08:37 PM
NC
440Jim Offline
440Jim  Offline
NC
Depends on the cam, intake, headers, converter stall, etc. etc.
But until you list that, I would say 2% more power.
So if you are making 1000 hp that would be 20 hp.
And a 12 second car adding 20 hp would be 0.2 seconds in the 1/4 mile. So it depends what you have and what it runs ...
Re: Difference between 10.5 and 11.0 cr [Re: 440Jim] #1283132
08/10/12 10:09 PM
08/10/12 10:09 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
408 Indy headed
I was hoping to gain .2 sec in the 1/8 mile...
just by swaping to thinner head gaskets....cheap horsepower to me , go from 6.75 to 6.55..
Dan
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283133
08/10/12 10:23 PM
08/10/12 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
408 Indy headed
Dan
I think your asking alot for just the head gasket
but thats... JMO
Re: Difference between 10.5 and 11.0 cr [Re: MR_P_BODY] #1283134
08/10/12 10:28 PM
08/10/12 10:28 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Depends on where your quench distance is now,and where it will end up after the swap. Not hard at all to gain 20 hp fixing a bad quench.
Keith
Re: Difference between 10.5 and 11.0 cr [Re: 440Jim] #1283135
08/10/12 10:46 PM
08/10/12 10:46 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I have read about the diminishing returns in torque from CR increases. That makes sense, but I also wonder how it could possibly fit into the 'whole picture' of matching parts. Like Jim said- depends on the other parts.
I have 0 experience with race gas territory compression ratios but I suspect that if increases give diminshing returns then the primary reason for a 15:1 cr in a race setup would be to maximize the performance of a wild cam with lots of overlap.
So if your CR is low for what your cam wants maybe your gains could be greater?
I'm only guessing- I'd love to hear from someone that actually knows.
Re: Difference between 10.5 and 11.0 cr [Re: radar] #1283136
08/10/12 11:40 PM
08/10/12 11:40 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I think you should check your cylinder pressure, you may be able to bump it up one whole point if you find out your cylinder preesure is around say 150 pounds now.
Re: Difference between 10.5 and 11.0 cr [Re: Darryls-Demon] #1283137
08/11/12 12:33 AM
08/11/12 12:33 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Cylinder pressure is 180lbs.....may be the cam is asking for more ???
255*/263*@ .050 solid roller..
Dan
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283138
08/11/12 01:03 AM
08/11/12 01:03 AM
Northern Indiana
Northern Indiana
What's the lsa ?
Keith
Re: Difference between 10.5 and 11.0 cr [Re: Dunnuck Racing] #1283139
08/11/12 02:15 AM
08/11/12 02:15 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
lsa is 110........
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283140
08/11/12 04:31 AM
08/11/12 04:31 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
408 Indy headed
Dan
At your level of performance, you will not see a 2 tenths gain with a 1/2 point comp increase. Nope/No way!
If your running 6.75,s now, with that 1/2 point bump, Id expect high 6.68,s or so.
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283141
08/11/12 11:52 AM
08/11/12 11:52 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Difference between 10.5 and 11.0 cr [Re: Sport440] #1283142
08/11/12 12:22 PM
08/11/12 12:22 PM
Glendale Az
Glendale Az
408 Indy headed
Dan
With 440sport, its not like your cylinder pressure is low now so I just can not see how a 1/2 point more will make that much difference.
Re: Difference between 10.5 and 11.0 cr [Re: Darryls-Demon] #1283143
08/11/12 04:53 PM
08/11/12 04:53 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Oh Thanks for all the good advice !
Dan
Re: Difference between 10.5 and 11.0 cr [Re: Wedgeman] #1283144
08/11/12 06:20 PM
08/11/12 06:20 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
Little to no gain unless the tighter quench fixes something,maybe 10 hp.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Difference between 10.5 and 11.0 cr [Re: BIGSPEED] #1283145
08/11/12 10:19 PM
08/11/12 10:19 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
what is your complete combo/weight .your 2 tenths may be in advancing cam ,gear change ,stall etc
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
