Sure grip problem #1282223
08/09/12 10:40 PM
08/09/12 10:40 PM
Brandenburg, Kentucky
green-duster Offline OP
Ok my duster is a fresh build from front to back, and I have not driven it on the street yet. The rear has 3.23 gears and is suppose to be a suregrip, but when I put it in gear and give some gas on the slick garage floor only the passanger wheel spins, so Im thinking its a open end. But when I jack it up in neutral and spin the rear wheels they both spin in the same direction, and when it is in park the back wheels are locked tight and wont turn. Correct me if im wrong but these are signs of a sure grip right.
Re: Sure grip problem [Re: green-duster] #1282224
08/10/12 12:29 AM
08/10/12 12:29 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My axle guy "Shawn" told me that a loose, worn out Sure Grip will show the signs that you stated. The key is at which point the guts break free and allow one tire to spin while the other sits still.
The test is to have the 3rd member out for a test. Shawn sets the unit in a axle shaft bolted in a vise. He then inserts another axleshaft in the other end then puts a torque wrench on it. A new SG unit should hold 130 lbs of torque before breaking free. A decent used one should hold 90-100 lbs. I took an old Cone type in to have checked out. It failed at 30 lbs! In a straight line on dirt, it spun both tires. Turning right it would just spin the right tire!
Re: Sure grip problem [Re: Kern Dog] #1282225
08/10/12 02:00 AM
08/10/12 02:00 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You can do the same test without taking the rearend apart. Jack it up onto jack stands. Have a buddy hold 1 tire while you turn the other 1. If your buddy can hold it the unit needs rebuilt..
I am truckless..
Re: Sure grip problem [Re: green-duster] #1282226
08/10/12 03:09 AM
08/10/12 03:09 AM
Illinois
fishy68 Offline
fishy68  Offline
Illinois
Sounds like a worn out sure grip unit. My Cuda did the exact same thing when I bought it.
68 Cuda 408/904/8-3/4
02 Dakota 4.7 auto
Re: Sure grip problem [Re: green-duster] #1282227
08/10/12 10:18 AM
08/10/12 10:18 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If it's an original rear to your duster it's a cone type ... POs ... it's on it's last legs .
Jack one wheel off the ground , put it in neutral , choke the front wheels and try to turn the wheel that is off the ground .
Re: Sure grip problem [Re: JohnRR] #1282228
08/10/12 11:17 AM
08/10/12 11:17 AM
bear hug it & try to turn it forward. Holler what you get
Re: Sure grip problem [Re: JohnRR] #1282229
08/10/12 03:36 PM
08/10/12 03:36 PM
P
Paul_Fancsali Offline
P
How many parts referring to cone style POS last for over 40+ years? I have no issue with the cone style sure grips refurbish it and it will work for another 20-40 years
