Re: Break in oil [Re: moparpollack] #1282058
08/10/12 03:22 PM
08/10/12 03:22 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
it's my understanding that diesel oils have the right amount of zinc in them. since i don't know that to be 100% true with a synthetic blend oil i would just get 2 bottles of Lucas breakin additive and one to the break in oil and the other after you change it. most auto parts stores have Lucas.
As far as the diesel oil, they or may not have enough zinc...If you have moderate to high spring pressure, probably not. Id still add a bottle of Comp, EOS, etc.
I know nothing about the Lucas break in oil. Id like to see a lab report on it. If its like the rest of the Lucas stuff...run...
EDIT. Found some info on the Lucas break in oil, looks to be good stuff.
No zinc in any of the deisel oils since they put the cats on them since the zinc plugs them up.
Current heavy duty (diesel) oil has about 1200 ppm zinc...some a bit more, some a bit less. That amount is good for a stock engine. Modified engines need more due to spring pressures and such. Get your facts straight.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Break in oil [Re: dogdays] #1282059
08/10/12 05:49 PM
08/10/12 05:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Here goes nothing.....
You guys are deep into the More's Better theory.
You know, if some is good, more's better and too much is just right!
At least take the time to read the Joe Gibbs literature on Diesel oils. His point is, the extremely high detergent levels in the oil for diesel engines makes it harder for the ZDDP molecules to find a place to stick to. So you can have all the ZDDP in the world but if it can't find a surface, it doesn't do a lot of good.
Several years ago on this board a member detailed an experience with Diesel oils and lubrication failure on a new extremely high output engine. Most pooh-poohed the story, but he had no reason to lie about it. Maybe there is a hidden weakness in the Diesel formulations.
I think that the "use Diesel oil" theory is an article of faith among the believers and expect that its believers cling to the idea out of a religios fervor. Maybe it's time to open our eyes.
R.
i also believe this to be true. the theory of oil is oil simply isn't true once the blending for different applications starts happening.
Re: Break in oil [Re: CompWedgeEngines] #1282060
08/10/12 06:20 PM
08/10/12 06:20 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
will not be any problem whatsoever being a semi synthetic. You dont NEED a dino oil to break an engine in...the internet can be a dangerous place....
Todd,
Not trying to argue, i was just repeating what Total Seal and other ring mfgs have told me .
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Break in oil [Re: dogdays] #1282061
08/10/12 06:21 PM
08/10/12 06:21 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
The only problem is Comp and other mfgs specifically suggest Rotella and other diesel oils to use for break in. I would assume that Comp has a handle on detergents and their effects
On the subject of too much zinc can be a bad thing...If we take a base oil with X amount of zinc, add an additive to make the total zinc content B. How much higher of a total zinc content do we have than the zinc content of the oils from the 60s-80s? Its all simple math, I know. But without a VOA from a qt of SH, SG etc oil, etc, Im not sure we can answer that fully. But, Id say its rather important...
Re: Break in oil [Re: Von] #1282062
08/10/12 11:41 PM
08/10/12 11:41 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Re: Break in oil [Re: dogdays] #1282063
08/11/12 12:20 AM
08/11/12 12:20 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
just off the top-of-my-head, I'm not sure Joe Gibbs is right on the "too much detergent" causing ZDDP to not be effective...
...again, without reading too much about it, just knowing how solutes act in solution, I don't think ZDDP needs to *stick* to metal in order to be effective. I guess I've always thought of ZDDP to be like a pressure additive more than anything. It always stays in solution, not necessarily sticking to anything, and as the flat-tappet tries to compress the oil and contact the camshaft, the ZDDP is more or less compressed, and sliding along smoothly against other ZDDP molecules, but always remaining in solution.
The presence of ZDDP (again, I would *imagine*) simply means the oil can withstand more pressure/compression without being displaced off the lifter/cam surface, allowing the oil to be the primary lubricant.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: Break in oil [Re: Prince_Valiant] #1282064
08/11/12 02:32 AM
08/11/12 02:32 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Regarding the detergents in diesel oil rendering ZDDP weak; I'd take a close look at the source of that assertion.
The formulators know how to bring these components together in a way that's effective. For example, API CJ-4 still has healthy amounts ZDDP. Take a look at the test summary for API CJ-4 by clicking HERE
Notice they're evaluating mushroom-style slider tappets in the Cummins ISB. Is Cummins going to approve an oil with an inherently weak anti-wear package? Probably not; they don't.
There's a lot of research and technology that goes into a properly blended motor oil. Read more about it here: What's In Your Motor Oil? - link
Re: Break in oil [Re: CompSyn] #1282065
08/11/12 06:10 AM
08/11/12 06:10 AM
salem, oregon. usa
E
elmor Offline OP
elmor  Offline OP
E
salem, oregon. usa
I drained the synth-blend and believe it or not, Walmart has SE/SF rated oil that specifies it has the same zinc content as needed for pre-1988 engines. Talked with my local Mopar guru and he told me thats what he uses in all his flat tappet engines. He said to use it and a bottle of STP. The STP states that it has the ZDDP needed. Broke in the cam yesterday and everything is fine.
Re: Break in oil [Re: elmor] #1282066
08/13/12 11:10 AM
08/13/12 11:10 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
30 Weight Brad Penn
MLR426
Re: Break in oil [Re: elmor] #1282067
08/13/12 01:58 PM
08/13/12 01:58 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
For use after break-in I caution the use of ancient API oil category dollar store oil. As it would seem, there is a nee-jerk reaction among some to avoid SN/SM rated modern oils altogether. Yes these newer oils are down about 400ppm in the anti-wear additive ZDDP that we’d like to see but the fact of the matter there are a vast number of improved characteristics of the new oils over the old ones. Even SN is improved over SM.
For example, below is a list of some of the benefits one can expect with regard to improved performance characteristics of an SN rated oil versus ANY retired API category oil that came before it.
- Improved Seal Compatibility
- Improved Rust Protection
- Improved Fuel Economy (Which may mean reduced friction and improved power)
- Less volatile
- Improved Engine Sludge Protection
- Improved Piston Cleanliness
- Improved Oxidative Thickening Protection
So, if one prefers to mix their own anyway with the ZDDP additive of their choice, why not at least start with a motor oil formulated with superior base oils and the modern additive package; the best of both worlds as it were.
Back to engine break-in. For favorable results, use a dedicated engine break-in oil that doesn't have friction modifier additives.
