Neutral start switch #1281720
08/08/12 09:20 PM
08/08/12 09:20 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
Doing a re-wire on a '53 Ford F100 panel truck. Running Chrysler 360 with 904. Trying to figure out how to wire the neutral start switch. I have three prongs on the switch and I have the plug from the donor car. I know one prong is power, one is backup lights and one is neutral start. Which prong is which? Also, I don't know is how to wire the neutral start. Is there another part on the column I am missing? I am using an ididit column, so no switch parts there.
Thanks for any help.
TJ
Re: Neutral start switch [Re: 53fopar] #1281721
08/08/12 09:50 PM
08/08/12 09:50 PM
moparx Online content
moparx  Online Content
the center wire completes the ground circuit to the starter relay. the outer 2 wires are for the back up lites. hope this helps.
Re: Neutral start switch [Re: moparx] #1281722
08/08/12 10:23 PM
08/08/12 10:23 PM
You could switch to an earlier one-wire neutral start switch that would have one stud and a nut to attach the single wire. Not necessary, just would look a bit neater.
Re: Neutral start switch [Re: moparx] #1281723
08/09/12 09:46 AM
08/09/12 09:46 AM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
OK, let's see if I have this right. The wire from the relay (on the firewall) to the starter solenoid gets cut and routed to the neutral safety switch and then back to the starter solenoid. If the trans is in neutral, the current goes through neutral start switch and allows starter to turn. If not in neutral, switch allows no current and no start. Is that how it works?
Is all I need is the center post with a wire from the firewall relay to the neutral start and then on to starter solenoid. Or does the wire from the firewall relay go to the power pole on the neutral start and then a wire from center pole to solenoid? Seems like I need a wire in and a wire out if it works like a switch? I am confused....
Re: Neutral start switch [Re: 53fopar] #1281724
08/09/12 12:47 PM
08/09/12 12:47 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
no, the center wire on the NSS is a ground for the wire coming from the starter relay.
the starter relay will only work when it is grounded,
the trans has to be in neutral or park for ground...
the 2 outer wires on the NSS are the + in and out to the back up lights, when you are in reverse it completes the circuit Ron...
Re: Neutral start switch [Re: Mopar Ron] #1281725
08/09/12 12:54 PM
08/09/12 12:54 PM
Mopar Ron Offline
Mopar Ron  Offline
maybe this will help.
the angled push on wire should be start from your key and the other push on wire goes down to the middle wire on the NSS Ron...
Re: Neutral start switch [Re: Mopar Ron] #1281726
08/09/12 02:43 PM
08/09/12 02:43 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
Slowly, I am starting to get it. Sorry for being so thick.
Ron, my problem is I am not using the MOPAR starter relay. I am using the Ford relay. The Ford relay as one terminal for the battery connection and one to the starter solenoid just like the MOPAR. There are two more terminals, one is "coil" where the wire from ignition goes and the other is "ignition". I am guessing the wire should run from the "ignition" post on the relay to the center post on the neutral start switch. Nothing to the solenoid.
Re: Neutral start switch [Re: 53fopar] #1281727
08/09/12 03:02 PM
08/09/12 03:02 PM
Mopar Ron Offline
Mopar Ron  Offline
personally I would use a mopar relay since you are using a mopar engine and they are set up for the mopar NSS.
ford has a different set up for Neutral, I believe it is on the column or on the shifter.
the Mopar one is much easier.
mopar starters have 2 wire.
ford only uses 1 wire (battery cable)
is there a NSS on your column or your shifter?
Re: Neutral start switch [Re: Mopar Ron] #1281728
08/09/12 05:41 PM
08/09/12 05:41 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
No nothing on the column or shifter. Using an ididit with column shift. I'll have to research how the Ford relay works and figure out what to do. May just skip the neutral start thing.
Thanks for the help.
Re: Neutral start switch [Re: 53fopar] #1281729
08/09/12 06:28 PM
08/09/12 06:28 PM
Mopar Ron Offline
Mopar Ron  Offline
For safety reasons I would not go without a NSS.
I have seen some weird things happen.
why do you want to use the ford starter relay?
just replace it with the mopar one, problem solved.
the mopar one is smaller than the ford unit anyways
they are easy to wire in and work great. Ron...
Re: Neutral start switch [Re: 53fopar] #1281730
08/09/12 06:36 PM
08/09/12 06:36 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
When using the Ford style firewall solenoid you can't use the ones that have the "I" and "S" terminals, you have to get the type that has two un-labled terminals and then run the Start wire to one terminal and the other terminal goes to the center pin on the Mopar NSS.
At the Mopar starter you will need to run a jumper wire between the large terminal and the smaller "S" terminal.
Re: Neutral start switch [Re: John_Kunkel] #1281731
08/09/12 06:45 PM
08/09/12 06:45 PM
Mopar Ron Offline
Mopar Ron  Offline
well there you go
John do you know what the # is or what year that it fits?
that is good to know... Ron...
I still like the mopar one better
Re: Neutral start switch [Re: Mopar Ron] #1281732
08/10/12 12:15 AM
08/10/12 12:15 AM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
No special attachment to the Ford relay other than the fact I have all the wiring under the hood done. I'll look into the un-labeled Ford relay since it would be a simple swap out.
Thanks everyone for the help.
Re: Neutral start switch [Re: Mopar Ron] #1281733
08/10/12 01:51 PM
08/10/12 01:51 PM
Rio Linda, CA
Rio Linda, CA
Most Mopars prior to '62 used one that will work or a generic solenoid like a Cole-Hersee #24143
Re: Neutral start switch [Re: 53fopar] #1281734
08/11/12 03:38 PM
08/11/12 03:38 PM
Rio Linda, CA
Rio Linda, CA
If you'd prefer to retain the current solenoid and underhood wiring, you can incorporate the NSS by installing an ISO relay under the dash. See schematic below.
Re: Neutral start switch [Re: John_Kunkel] #1281735
08/11/12 06:03 PM
08/11/12 06:03 PM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
Wow, thanks John.
Just a few questions. I am using the old starter button. I assume the wire from the start switch replaces the wire from the starter button to the Ford relay. Also, it was hard to read, does the wire going to the starter solenoid go to the start wire (small wire) or the battery cable wire (I am guessing the small wire)?
Can I get this at NAPA?
Re: Neutral start switch [Re: 53fopar] #1281736
08/12/12 03:16 AM
08/12/12 03:16 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
learning some thing here,,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Neutral start switch [Re: 53fopar] #1281737
08/12/12 05:44 PM
08/12/12 05:44 PM
Rio Linda, CA
Rio Linda, CA
OK, we're interchanging the word "relay" with the word "solenoid"....the ISO relay in my drawing will be added to the start circuit and energizes the existing Ford solenoid. The ISO relay is available from many sources, just ask for a "30 Amp ISO Relay"....most come with the connector and short pigtail wires.
The solenoid I'm referring to is the existing Ford firewall solenoid; the existing wire that now goes from the Start button to the solenoid "S" terminal is interrupted by the ISO relay in my schematic I.E. the existing wire goes to terminal 86 and jumpers across to 87. The wire from ISO terminal 30 goes to the "S" terminal on the existing solenoid and terminal 85 goes to the center pin on the NSS. This way the starter will only be powered in Park and Neutral by a ground from the NSS.
As before, in order to use the Ford solenoid with the Mopar starter you will need a jumper between the two terminals on the Mopar starter; this is assuming you are powering the Mopar starter large terminal from the Ford solenoid large output terminal.
But if you are hooking the battery positive cable directly to the starter and using the Ford solenoid only as a relay, no jumper is needed and the output side of the solenoid would go to the small "S" terminal on the Mopar starter.
Confused yet?
Re: Neutral start switch [Re: John_Kunkel] #1281738
08/13/12 12:08 AM
08/13/12 12:08 AM
pensacola, fl
53fopar Offline OP
53fopar  Offline OP
pensacola, fl
I got it John. I only have to mount the new ISO relay under the dash, interrupt the start wire from the starter button to the S terminal on the Ford relay and wire it to the ISO relay in two spots and then run one new wire down to the neutral start switch. Oh, and add small jumper wire at the starter solenoid since I am using the start terminal on the Ford relay.
Yeah, I was confused about the use of "solenoid". I've always called the thing on the starter that engages the bendix gear a solenoid. Anything else I call a relay. But I have heard many people call the thing on the Ford firewall a solenoid.
Anyway, it's all good. You're the best, thanks for the help. If you get to Florida, I am buying...
Re: Neutral start switch [Re: 53fopar] #1281739
08/13/12 01:35 AM
08/13/12 01:35 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
essentially, the difference between a solenoid and a relay is the amount of current they handle. They function the same. They both use an electromagnet to engage a set of contacts, in the case of a starter solenoid it will also engage the bendix.
Don't be the exception.
