Re: Trunk lip numbers
[Re: 70Runner440+6]
#1281560
08/08/12 04:07 PM
08/08/12 04:07 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I think there might be numbers under the rear package tray also depending on what year car this is. (core support, dash or doorjam, package tray and trunk lip)
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: 70Runner440+6]
#1281563
08/08/12 04:22 PM
08/08/12 04:22 PM
Posts: 18,679 Fresno, CA
Jim_Lusk
Fresno, CA
Hi all, I recently looked at a car that interests me but the trunk lip numbers didnt match the rad support, vin, fender tag and bs. Theres no evidence of sheet metal replacement in that area, were these numbers ever incorrectly stamped or is it a rebody? thanks
Sounds like a re-body to me. Does it look like the rad support was replaced? Consider, though, that it was fairly common back in the 70s to put the front half of one car onto the back half of another for collision repair. All this does is cloudy up the car you are looking at. A full history of the car would clear things up.
My 67 Barracuda convertible trunk lip and rad support don't match, but there is strong evidence that the rad support was replaced back in the 1970s from a font end collision.
[Re: Jim_Lusk]
#1281564
08/09/12 09:56 AM
08/09/12 09:56 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
Hard to call it a rebody without seeing the car. If someone went to the trouble of doing a rebody and changing numbers you'd think they would have changed that number also or at least erased them???
It could have had the rear quarter replaced and whomever did it changed the trunk lip along with the quarter?
My Dart was crashed , it had half the core support replaced and the numbers are gone, and the left quarter is a used replacement but the trunk lip number was not touched, luckily ...
[Re: Savoy1964]
#1281565
08/09/12 09:58 AM
08/09/12 09:58 AM
JohnRR
Not on a 69 B body , rad support and trunk lip only , aside from the VIN on the dash and the fendertag.
[Re: 70Runner440+6]
#1281566
08/09/12 10:00 AM
08/09/12 10:00 AM
JohnRR
the car was restored supposedly about 10 years ago and the numbers arent even close. I assumed it was a rebody but wasnt 100% sure if there were ever mistakes on the stampings, thanks
If the car was restored then it would be hard to tell what was done , especially if the car was done concourse incorrect with everything painted that never was originally. What the trunk lip number from a car built at the same plant at least ?
either way something was replaced ...
