High crankcase pressure? #1281444
08/08/12 01:45 PM
08/08/12 01:45 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
I have noticed that I am blowing oil out of the dipstick tube, and pushing the dipstick out. Is this an issue of high crankcase pressure or oil level too high?
The car sat a few years, and I just started driving it alot lately. now that I think back, I used to run the oil a little "low" and picked up a few tenths with no adverse effects.
360
stock pan/pickup
hi volume oil pump
PCV (new valve)
breather in other valve cover
No signs of excessive blowby out of the breather. Engine has ~7k miles, <100 passes. I am worried that sitting may have messed with how the rings are sealing...but it doesn't smoke at all, even at the track. So should I just stop worrying and drain a 1/2 qt out of it??
Thanks!
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: High crankcase pressure? [Re: OUTLAWD] #1281445
08/08/12 01:51 PM
08/08/12 01:51 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I would dump a little out of it and give it a try.
Re: High crankcase pressure? [Re: OUTLAWD] #1281446
08/08/12 01:54 PM
08/08/12 01:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Easiest thing to do is drain a little oil out then
try it again.... but my opinion is the pressure getting
past the rings... but see if they set in... you dont
want to do what I'm doing now unless its needed
Re: High crankcase pressure? [Re: MR_P_BODY] #1281447
08/08/12 02:28 PM
08/08/12 02:28 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
It looks like I'll be pulling the heads over the winter to do head gaskets...weeping a little water out of the front...figure at that time I might as well upgrade the bumpstick, etc...but I'd really like to be able to leave the bottom end alone for now, and focus time/energy on a new build instead of rehashing this one...
will do comp/leakdown when I remember to borrow the kit from work. but the oil level is an easy check for now
Re: High crankcase pressure? [Re: OUTLAWD] #1281448
08/08/12 06:27 PM
08/08/12 06:27 PM
Cab_Burge Online work
Cab_Burge  Online Work
Pull the breather cap and see if it blows oil out of it when revving it under a load, like a full pass I have taped a shop rag folded up over the oil filler holes to see if te motor was blowing oil do to crankcase pressure BTW, some breather caps have very little holes in the bottom to let the crankcase pressure out, I switched my stroker motor over to a set of Mr Gasket breather caps and that cured my oil dipstick from blowing out after several runs with the other breather caps
Re: High crankcase pressure? [Re: Cab_Burge] #1281449
08/08/12 08:55 PM
08/08/12 08:55 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Thanks! Can't hurt to try...
I had one of the on the pass side with a baffled gromet
and a PCV on drivers side. Just replaced the fill cap with one of these I had laying around
Re: High crankcase pressure? [Re: OUTLAWD] #1281450
08/08/12 10:55 PM
08/08/12 10:55 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I had to put a spring on my duster it was blowing the stick out 3" every pass and blowing oil out of Hughes valley pan.I put a pump off of a 2000 firebird it stopped all of it.
Section 8 Racing We are nuts about racing.
Re: High crankcase pressure? [Re: bentwheel43] #1281451
08/08/12 11:02 PM
08/08/12 11:02 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
this is the other side and I put the stock valley pan back on.
Re: High crankcase pressure? [Re: bentwheel43] #1281452
08/08/12 11:50 PM
08/08/12 11:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Why run a breather on it with a vac pump.... just
put a adjustable relief valve set at a point IF that
pump can pull enough vac
Re: High crankcase pressure? [Re: MR_P_BODY] #1281453
08/09/12 12:20 AM
08/09/12 12:20 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
when I pull the breather off and put my hand over it it sucks good and speeds the pump up when the cap is off.It got the pressure out of the motor.It also pull the water out as well as some oil maybe 3 oz in 8 or 9 passes.Stopped all the leaks it problilly would suck harder and maybe hurt the pump maybe becauce it will slow it down alot if I put a cap on it..I thank it cost about $125 for every thing.
Re: High crankcase pressure? [Re: bentwheel43] #1281454
08/09/12 12:34 AM
08/09/12 12:34 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Isnt that the GM vac pump..... what car/truck is it for
Re: High crankcase pressure? [Re: MR_P_BODY] #1281455
08/09/12 01:23 AM
08/09/12 01:23 AM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
2000 firebird,it works real good keeping the water out of the valve cover.On a friend sb chevy it pulls 5# @ the stick tube.I don't know if he has a breather on it.
Re: High crankcase pressure? [Re: MR_P_BODY] #1281456
08/09/12 11:39 AM
08/09/12 11:39 AM
Hobart,Indiana
MoparPitBull Offline
Hollywood
Hollywood
Hobart,Indiana
Yes Mr.Body...GM smog air pump used on '99 Corvette.Used them on a few alky motor cars to remove condensation from oil...a poor mans vacuum pump so to speak.Must be mounted in correct position to work best.Advance Auto part #32-2600M @ $95 w/warranty.
Re: High crankcase pressure? [Re: MoparPitBull] #1281457
08/09/12 11:48 AM
08/09/12 11:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Any idea what the amp draw is on them... what size
fuse they run
Re: High crankcase pressure? [Re: MR_P_BODY] #1281458
08/09/12 12:11 PM
08/09/12 12:11 PM
Hobart,Indiana
Hollywood
Hollywood
Hobart,Indiana
No...don't know the amp draw. Had it set up with its own toggle w/20 amp fuse. Only problem ever had was the foam on the inside of pump would get mushy from combination of oil/condensation...started bringing it back at beginning of season taking advantage of warranty. And sorry, its Mr.P Body..lol
Re: High crankcase pressure? [Re: MoparPitBull] #1281459
08/09/12 06:29 PM
08/09/12 06:29 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
hmm...I may try that pump out regardless of my problem, always wanted to try out a vac pump.
Mr.P, what kind of vacuum should I look for if I am setting a relief valve? Too much is a bad thing in this case, correct?
Re: High crankcase pressure? [Re: OUTLAWD] #1281460
08/09/12 06:55 PM
08/09/12 06:55 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
I suck 3 or 4 oz. of oil on 8 passes with a breather may suck more if I cap it.The cool air gose in the motor it never blow the stick out again,keeps the water out.I drilled a hole and got that fitting from Star mach about $37 bucks toggle with 20amp. pump was about $27 ebay $8 for shippng.You won't want to run it all the time just running it.We do the burnout then turn it on.
Re: High crankcase pressure? [Re: OUTLAWD] #1281461
08/09/12 08:34 PM
08/09/12 08:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It would depend on the pump.... on my dry sump I can
get 12"HG with just the pump so I dont run a vac pump
on it... if I were to use that I might set it at 5"
to 6"HG... because I would think (from what the others
are saying it might not like more) but I would have
to see what the pump can do
Re: High crankcase pressure? [Re: OUTLAWD] #1281462
08/09/12 08:53 PM
08/09/12 08:53 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
From listening to the radio chatter from the Denver NHRA race, someones crew member reported " data logger on, vacuum pump on" So I assume they are also useing an electric vacuum pump. Not like the one mentioned here, I'm sure, but be looking into one for my car too.
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: High crankcase pressure? [Re: Dave_S] #1281463
08/10/12 12:50 PM
08/10/12 12:50 PM
Metro Detroit
OUTLAWD Offline OP
OUTLAWD  Offline OP
Metro Detroit
Doing some msg board searching, it appears as if a similar ford part off a 90's Cobra might be better.
Didn't find it available anywhere though...
F6ZZ-9A486-DA
One guy seemed to be blowing 20A fuses, Buit I'm not sure on his setup. There is some internal foam on the GM units that may restrict it, and it is suggested to remove it.
