Re: Is it normal for the fuel filter to drain?
[Re: TomZ]
#1281303
08/08/12 05:01 AM
08/08/12 05:01 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I fuel filter is usually never full, even when the engine is running.. You say you can "see" in it. Do you have a glass filter or a plastic one? Either way Id recomend changing to a metal filter for the sake of safety..
I am truckless..
[Re: ahy]
#1281308
08/09/12 02:52 PM
08/09/12 02:52 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
no, it shouldn't drain. mine did, ended up having a small leak in the hose tying the hard line to the fuel pump inlet.
[Re: ahy]
#1281309
08/09/12 09:03 PM
08/09/12 09:03 PM
DaytonaTurbo
Manitoba, Canada
The factory pump has a check valve. It may not be sealing completly or the gas may be evaporating as posted above.
Evaporating from where? Inside the fuel filter? That's some magic evaporation if it can evaporate from inside a fuel filter. If your car is hard to start after sitting for a day, it's because the fuel is evaporating out of the carb and it takes some cranking to refill enough fuel into the bowl to fire it.
[Re: DaytonaTurbo]
#1281310
08/09/12 11:00 PM
08/09/12 11:00 PM
Posts: 15,487 Florida
scratchnfotraction
on a BB engine the fuel pump can ruptur and dump fuel in the crankcase and kill the engine is short order. on a SB engine the fuel pump has a weep hole that will let the line from carb to fuel pump drain down. check to make sure the pump is not ruptured and leaking the fuel. some of it is heat soak/fuel perk/evap with the crappy gas. the ethel will evap very fast and need to refill the bowl on start up. you can add a check valve in the line,but a good working stock system should hold the fuel for DAy or so. IMO..mine does. also check the steel line from tank to pump,small pin holes can leak undetected. i found mine was full of pin holes you could not see,till after I slaped it on the floor a couple times to dislodge rust on the line. very plane to see after that. what carb is it? some fuel bowls need to be epoxied at the jet well plugs for internal leaks.
[Re: TomZ]
#1281313
08/10/12 09:35 AM
08/10/12 09:35 AM
patrick
Grand Haven, MI
Thanks. Yes, after a few days it takes a little more to start it. I think everything after the fuel pump goes dry.
I'll check everything after the fuel tank for leaks. Some sections of metal fuel line are original, still covered by undercoating from 40 years ago. There's no obvious leaks, but I've never examined it closely either.
Carb is an Edelbrock 1406, 600 cfm.
mine was on my slant. wasn't enough of a leak to actually show fuel dripping or wetness, but it made the garage stink.
