Re: What alternator amperage should I use?
[Re: 71yelladustr]
#1281131
08/08/12 09:51 PM
08/08/12 09:51 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
There is something about seeing a GM alternator on a Mopar that makes me want to They do work though. I got a 120 amp Denso on my car and it works well.
I always found this funny because Denso is owned partially by Toyota. I've never been sure why installing a USA made GM part (many Mopars have GM Saginaw P/S pumps and steering columns) is bad, but a Japanese part is ok on an old Mopar? We use 10SI/12SI Delcos on everything, street rods, muscle cars, 40's/50's cars in 12V conversions, farm tractors, etc. Install and forgetaboutit. If you use a denso, for God's sake get one with an internal regulator, the mopar regulator (especially the ones you get from parts stores anymore) are garbage.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: challengermike]
#1281136
08/09/12 12:41 PM
08/09/12 12:41 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
If you don't "update" the rest of your electrical system using the basic principles discussed on Mad Electrics website, you are risking some serious problems by running a higher output alternator with all your additional electrical load.
I ended up using an upgraded (rewound w/ heavy duty bridge rectifier & regulator) AC Delco CS 144. The comes in Escalades and some full-sized pick-ups etc. It essencially bolts right in with a simple adaptor. It puts out 115+ amps at idle & over 200 amps above a fast idle.
However, the more difficult & time consuming part of the complete electrical system upgrade job, is to wire the car to be able to safely distribute and protect the wiring system.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
