Drag Radial Clearance #1280894
08/07/12 11:39 AM
08/07/12 11:39 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
How much clearance do you guys like to see between the front of your drag radials and the front wheel arch??? In other words- How much do they grow in diameter??
Re: Drag Radial Clearance [Re: mopowers] #1280895
08/07/12 12:20 PM
08/07/12 12:20 PM
They don't grow near as much as the bias plys do, the amount of growth will vary depending on MPH of course, IE no growth at 100.00 MPH , 1/2 inch diameter of growth at 130 MPH or so. This is a eaxmple, probally not very accurate
Re: Drag Radial Clearance [Re: Cab_Burge] #1280896
08/07/12 12:31 PM
08/07/12 12:31 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I have seen alot of drag radial cars that run really fast and run them very tight. I have seen them under a 1/4"
67' charger 499 RB 10.57 at 127
Re: Drag Radial Clearance [Re: dragram440] #1280897
08/07/12 01:28 PM
08/07/12 01:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
The almost don't grow at all. I have several buddies that have less than a 1/4" & are going over 200MPH on 315's. My 315's on my Challenger are about 1/4" all the way around also with no issues.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Drag Radial Clearance [Re: 6PKRTSE] #1280898
08/07/12 01:57 PM
08/07/12 01:57 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Thanks guys. I'm installing a set of ladder bars in my car and want to mount the rear as far forward as possible without fear of the tires hitting wheel lip. Would 1/2" be enough clearance?
Re: Drag Radial Clearance [Re: 6PKRTSE] #1280899
08/07/12 01:58 PM
08/07/12 01:58 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
The almost don't grow at all. I have several buddies that have less than a 1/4" & are going over 200MPH on 315's. My 315's on my Challenger are about 1/4' all the way around also with no issues.
Thanks for the picture! So you're saying you only have 1/4 at the front as well??
Re: Drag Radial Clearance [Re: mopowers] #1280900
08/07/12 04:41 PM
08/07/12 04:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Maybe a llittle more at the front edge. There is less than a finger width at the wheel lip, inner side of the wheel tub/frame rail.
