Rear Brakes Releasing Slowly #1280616
08/06/12 10:10 PM
08/06/12 10:10 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
Does anyone know what would cause my rear drum brakes to release very slowly from a stop? It takes approx 10-15 seconds to fully release..The pedal also feels spongy? The master cylinder is about 6 months old and the rubber brake lines look to be in great shape..I have bled all four wheels.
Re: Rear Brakes Releasing Slowly [Re: catman56] #1280617
08/06/12 10:30 PM
08/06/12 10:30 PM
IMGTX Offline
IMGTX  Offline
Make sure the brakes are properly adjusted also.
They may be bled but will they pump up?
With the engine OFF, pump the brakes 5 or more time to purge the vacuum from the booster.
Pump up and then step on the brakes hard and hold. If the pedal starts to drop there is a leak or the master cylinder is failing.
Re: Rear Brakes Releasing Slowly [Re: catman56] #1280618
08/06/12 10:32 PM
08/06/12 10:32 PM
S.W. Pennsylvania
markrr Offline
markrr  Offline
S.W. Pennsylvania
I had the same problem not too long ago. On my car the rubber brake hose going to the rear end was clogged.
Re: Rear Brakes Releasing Slowly [Re: markrr] #1280619
08/06/12 10:47 PM
08/06/12 10:47 PM
CT..USA
catman56 Offline OP
catman56  Offline OP
CT..USA
Thanks for the suggestions..I will give them a try tomorrow.
