Big Bolt Conversoin
#1280297
08/06/12 05:11 AM
08/06/12 05:11 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Since this is a question, I will post it here. Is the best way to change a small bolt a-body 8.75 over to big bolt pattern to use 10" drums? Are they really getting scarce, or is there still a supply to be used? The fronts I'm not real worried about, aftermarket has them covered if I can't find used stuff. Just heard/read 10" stuff is getting hard to find and was wondering about other options. Also the axles for the switch will probably be ordered from Dr. Diff. He seems to be the MAN. Thanks!
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
Re: Big Bolt Conversoin
[Re: OhioMopar]
#1280298
08/06/12 08:24 AM
08/06/12 08:24 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Where did you hear the rumor about a lack of 10" drums? Most everything out there from 73 has 10" drums, cars and trucks use the same droms.
I am truckless..
[Re: OhioMopar]
#1280300
08/06/12 11:03 AM
08/06/12 11:03 AM
RapidRobert
That may be that 10" SBP drums are getting scarce. I'd get a set of BBP axles with tapered bearings with the offset for BBP brakes then as said a set of common BBP 10" brakes. Might be a slight increase in overall width which'll affect your rim offset needed/tire clearance so check that out also
[Re: OhioMopar]
#1280301
08/06/12 11:06 AM
08/06/12 11:06 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Not sure where I read it. Fabo, maybe? It may not have been the drums as much as the backing plates for an 8.75? Or I'm completely wrong, which is fine, too!
If you want to try to keep the current A body brakes and just swap drums then that is the problem , the drums for that are not available anymore , if you switch to B/E 10" brakes , and the axle has that proper offset then you should be all set. Aftermarket axles for big blot conversion come that way , you have to ASK for them to be A body offset and then rework your drums .
[Re: Cab_Burge]
#1280304
08/06/12 04:32 PM
08/06/12 04:32 PM
OhioMopar
Mt.Gilead, Ohio
My plan is to find a set of brakes, then buy a set of Yukon or similar axles. I don't like the idea of redrilling things. It is not a must right now, that's why I am getting the research out of the way first.
[Re: AndyF]
#1280306
08/07/12 06:58 AM
08/07/12 06:58 AM
OhioMopar
Mt.Gilead, Ohio
Contact DoctorDiff. Cass will set you up with what you need.
I hear he is the man when it comes to MoPar diffs.
