Re: Valve Cover Bolt
[Re: dusterjp]
#1280108
08/05/12 11:06 PM
08/05/12 11:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
minimum thread effective engagement for any bolt is the same as the diameter.
So a valve cover bolt is 1/4-20, which means minimum engagement should be 1/4"
[Re: Supercuda]
#1280110
08/05/12 11:28 PM
08/05/12 11:28 PM
Posts: 4,799 ILL
MLR426
ILL
effective engagement ?? no disrespect and don't take it that way but with only a 1/4 inch effective engagement it would be tough to draw down a valve cover with gasket with only a 1/4 inch depth of thread in the head. You need more effective thread depth to pull down the valve cover. Compression of the gasket and the bolt will bottom out. Also for example when talking about effective thread depth with a certian diameter you have to take the torque of the bolt into consideration in certian applications, for 3/8 intake bolt tapered on the starting threads and sticking below the gasket surface I wouldn't torque the bolt to 25/30 ft pds and expect the threads to hold in the heads with a 1/4 inch of bolt thread taking the load. I would be afraid the the threads would pull in the heads. MLR426
[Re: Supercuda]
#1280112
08/06/12 12:01 AM
08/06/12 12:01 AM
Posts: 4,799 ILL
MLR426
ILL
MLR426
Effective engagement has NOTHING to do with a valve cover gasket.
It has to do with having enough engagement to proper stretch the bolt for it to do it's job and that MINIMUM is the same as the diameter of the bolt in question.
In case you haven't clued in it's NOT the maximum, it is the minimum required. You can have more and still be affective, you cannot have less though.
To further elucidate, that minimum is what is actually threaded into the hole, it does not include the portion that passed thru the gasket or the valve cover, that would be extra.
Ever notice how a standard nut will be as thick as the diameter of it's threaded hole? Now you know why.
If effective engagement has nothing to do with a valve cover gasket then why would you use the term of effective engagement on the original posters question ? He's asking about thread depth on the valve cover rail in which the gasket compression and correct thread depth will come into play correct ?
MMLR426
[Re: tboomer]
#1280115
08/06/12 12:19 AM
08/06/12 12:19 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
Go reread his original post.
To be honest I would NOT use a bolt in aluminum threads, I would use a stud and a nut.
What the small weasel guy says!!
X3 ...
otherwise , carry on ...
Martin , you need to understand , the small weasel guy is NEVER wrong ... in his little world anyway ...
But , he is correct about the effective engagement principle ...
[Re: JohnRR]
#1280116
08/06/12 12:23 PM
08/06/12 12:23 PM
Posts: 4,799 ILL
MLR426
ILL
Wasn't trying to offend anyone guys. I took it as though the poster must have had very sallow threaded holes in the cover rail, and with the compression of the gasket it would be impossible to compress the gasket before bottoming out with the 1/4 inch engagement rule to take effect with that depth. I didn't mean to give you a wedgey dude!!! I didn't think engagement had anything to do with proper thread depth to compress the gasket. MLR426
[Re: MLR426]
#1280117
08/06/12 02:17 PM
08/06/12 02:17 PM
Supercuda
About to go away
About to go away
up yours
To answer the question you thought was asked you would have to also know what gasket he's running and what valve cover. The bolt hole is blind so there is a limit to how long the bolt can be and have it still work.
As for you John, it isn't that I am always right, it's more that you are wrong so often.
[Re: Supercuda]
#1280118
08/06/12 02:23 PM
08/06/12 02:23 PM
Posts: 4,799 ILL
MLR426
ILL
Doesn't matter what gasket or cover,,,John you were right.
MLR426
