New upper control arm question/GTX #1279789
08/05/12 03:57 PM
08/05/12 03:57 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
I need new upper control arms which would you buy and why?
Thanks in advance.
http://chucker54.stores.yahoo.net/tuupcoarmse.html
or
http://chucker54.stores.yahoo.net/bebofuadupco.html
Re: New upper control arm question [Re: Dodgem] #1279790
08/05/12 04:04 PM
08/05/12 04:04 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
I hear good things about these.
http://www.firmfeel.com/tubuca_b.htm
They also have an extra gusset behind the ball-joint mount.
No I don't work for them
Re: New upper control arm question [Re: Dodgem] #1279791
08/05/12 04:09 PM
08/05/12 04:09 PM
The top one looks stouter but the bottom one could be adjusted without taking the ends/cam bolt assys out of the subframe
Re: New upper control arm question [Re: Dodgem] #1279792
08/05/12 04:14 PM
08/05/12 04:14 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I use Firm Feel's. Extra positive castor & good quality workmanship. The downside is that if you have to replace the bushings it will be a good deal more difficult than it is with the stockers.
Re: New upper control arm question [Re: 5spdcuda] #1279793
08/05/12 04:26 PM
08/05/12 04:26 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
So another option to ponder (firm feel)
Robert your right SPC looks like it would be quick and easy to install and have lined up. not sure all those bolts look as strong as I would like?
but on the other had QA1 looks a little stouter and you would only have to go through the big set up once.
Course the Firm fell may be the stoutest may be important at 130
any more thoughts and real life results?
Re: New upper control arm question [Re: Dodgem] #1279794
08/05/12 04:38 PM
08/05/12 04:38 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Whats the car used for??
street use, drag race == waste of money
racing rouny round or road corse go for it..
I am truckless..
Re: New upper control arm question [Re: 340SHORTY] #1279795
08/05/12 05:16 PM
08/05/12 05:16 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Drag racing now will find it's way to dual duty down the road again!
Re: New upper control arm question [Re: Dodgem] #1279796
08/05/12 06:00 PM
08/05/12 06:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I put a set of RMS UCA on my 71 demon (race only) along with the set of adjustable struts rods. The car has never been so consist...great weight transfer..
also with the increase caster dialed into the front end the car is more stable.
Tony
70 AARCuda Vitamin C
Re: New upper control arm question [Re: 70AARcuda] #1279797
08/05/12 06:58 PM
08/05/12 06:58 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
They heimed ones sure aren't a waste on a drag car.
Look up this guy he does nice work and the parts are solid.
http://www.dillingerchassis.com/
Re: New upper control arm question [Re: RobX4406] #1279798
08/05/12 07:11 PM
08/05/12 07:11 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Seems his stuff is Just A body??
Re: New upper control arm question/GTX [Re: Dodgem] #1279799
08/06/12 09:32 PM
08/06/12 09:32 PM
Ontario, Canada
Dodgem Offline OP
Dodgem  Offline OP
Ontario, Canada
Thanks Guys think I'm going with these QA1-52305
