Re: Question on 72 challenger gas tank with 4 vent nipples
[Re: patosmith]
#1279725
08/05/12 01:10 PM
08/05/12 01:10 PM
Challenger 1
Cincinnati, Ohio
My 72 Challenger project is in the "shell" stage with sheetmetal work coming to an end. So basically the fuel system is completely out of the car at this time. The car came with the gas tank that had the vent tube in the trunk and the tank with the 4 nipples. I plan to put a big block in the car. It will be streetable and hit the strip from time to time. I would like to get into the upper 10's with it. I don't want to put a fuel cell in the car. My question is should I ditch the vent system? Any suggestions on a good setup?
No do not ditch the vent system! Put it back togeather just like stock for a 71 E body hemi. It'll have 3/8" feed line and a return line. Get 3/8 sending unit with a return nipple and your golden for 10s easy. Your setup is just like mine and you will have a third line for the vent line that connects to the breather on the passenger side valve cover that's where your tank vents too, inside the engine. The right way so you never smell fumes in your garage.
[Re: burdar]
#1279731
08/05/12 04:03 PM
08/05/12 04:03 PM
Challenger 1
Cincinnati, Ohio
Very early 72's used the big vent tube in the trunk just like the 71's. I'm not sure exacly when they went to the small vapor separator on the shock x-member. It had to have been very early in 72 production.
[Re: Cab_Burge]
#1279734
01/20/13 11:56 AM
01/20/13 11:56 AM
Challenger 1
Cincinnati, Ohio
I cut the top of my 1971 Duster gas tank off, those same four lines allow gas to fill up all the way into the top corners Take a mechanics mirror and light and look at yours through the filler neck Don't block them off if you want a full tank
Those 4 line nipple are vents and each one goes to a upper corner of your gas tank. They insure the tank is vented no matter which way the car is parked. Don't have anything to do with complete filling. This is the inside of my 74 challenger gas tank. This tank sat with 110 leaded racing gas in it for over 17 years. I tried to keep it full and started the car about once a year. I am still using the same carb and gas tank from back in the 70s. You can see the 4 vent lines in this picture and look how heathly the tank looks for having been stored for 17 years and is the original 74 tank.
Racing gas is by far the best fuel to store your car with. I store lot's of small engiunes with racing gas also. Racing gas has stabilizers in it from the refinery and the lead is great for your car.
[Re: burdar]
#1279736
01/20/13 02:58 PM
01/20/13 02:58 PM
Posts: 705 Morningside, Long Island
scatcity
Approximately what IS considered "very early" SPD on the 72' models ? My '72 has an 810 ('71) SPD and is loaded with "leftover" '71 parts. IE: deck lid, wiring harneses', rear view mirror, all the glass, A883, etc. Though it does have the small vapor seperator on the shock x-member.
[Re: ogopogo]
#2699501
09/21/19 11:38 AM
09/21/19 11:38 AM
Posts: 12,237 Looking for a way out of Middl...
IMGTX
Basically the Junction box is the 4 vent lines going in the bottom with a vent tube going out the top and up to the Charcoal Canister in the engine compartment. Excess fuel that gets into the box should work it's way back into the tank through one of the 4 vent line and vapor goes up to the charcoal canister. I am not sure if there is an orifice or check valve in there. If you remove it, air should go in each of the 4 lower tubes and some should come out the top. If it's clogged try soaking it in Carb Cleaner. Those 4 line nipple are vents and each one goes to a upper corner of your gas tank. They insure the tank is vented no matter which way the car is parked. Don't have anything to do with complete filling.
Yes and no. It was not meant for filling the tank but by simple physics if the tank is parked in any position other than filler neck higher than the rest of the tank, It will trap air in the tank if they are plugged. Not it's purpose but it will have an effect.
