put in new distributor, runs horrible #1279571
08/04/12 11:41 PM
08/04/12 11:41 PM
Davis, California, USA
MrBelvedere2 Offline OP
I just put in a new stock replacement electronic distributor on my 383 in my 70 dodge truck that already had electronic ignition. The shaft was very sloppy on the old unit and was causing it to ping under load no matter what I would set it at timing wise. I put in the new unit, timed it in. It idles great, and runs great at higher RPM's. The thing is at above idle and cruise RPM, it backfires through the carb, and makes popping noises out of the exhaust. It bucks and pops, but does not die, like it is breaking up somehow in the mid RPM range. I only changed the distributor, so this is the only variable. Any advice? thanks!
1965 Plymouth Belvedere II hardtop
Re: put in new distributor, runs horrible [Re: MrBelvedere2] #1279572
08/04/12 11:49 PM
08/04/12 11:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
did you check the gap? should be .008
Re: put in new distributor, runs horrible [Re: mikemee1331] #1279573
08/04/12 11:58 PM
08/04/12 11:58 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Mikee is right. Use a BRASS feeler guage too.
Re: put in new distributor, runs horrible [Re: MrBelvedere2] #1279574
08/05/12 12:06 AM
08/05/12 12:06 AM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Does it have an adjustable vacuum advance? If it's bucking at cruise, sounds like too much vacuum advance. That's what mine does if I dial in too much.
68 Roadrunner. 383 4-spd. Beat up.
Re: put in new distributor, runs horrible [Re: Mebsuta] #1279575
08/05/12 12:43 AM
08/05/12 12:43 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Double check the plug wire firing order. It's easy to get two swapped.
Re: put in new distributor, runs horrible [Re: stumpy] #1279576
08/05/12 02:38 AM
08/05/12 02:38 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The pickups in the new MP distributors are crap. Swap out the pick up with your old one.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: put in new distributor, runs horrible [Re: HemiRick] #1279577
08/05/12 11:45 AM
08/05/12 11:45 AM
X2: pickup gap/bad pickup/too much vac adv. I guess too much vac adv timing and or rotor phasing. I'd unplug/cap the vac adv hose (easy check) & see if that makes it better/worse/no change & vac adv also alters rotor phasing
Re: put in new distributor, runs horrible [Re: RapidRobert] #1279578
08/05/12 12:29 PM
08/05/12 12:29 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Check for timing chain slop too.
Re: put in new distributor, runs horrible [Re: stumpy] #1279579
08/05/12 01:21 PM
08/05/12 01:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
And maybe it is over advancing is the vacuum hooked up and if it is to ported vacuum??
Re: put in new distributor, runs horrible [Re: Dodgem] #1279580
08/05/12 01:44 PM
08/05/12 01:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm running MP distrib and I was amazed how off the gap was in the thing. check that 1st.
Coming soon!!!!
Re: put in new distributor, runs horrible [Re: Mr.Yuck] #1279581
08/06/12 12:59 AM
08/06/12 12:59 AM
Ok I checked the gap, and it was .008 as it should be. It did turn out that the vacuum advance was way off, had to turn it clockwise with an allen wrench about 8 turns to get it to where it liked it. Runs great now. Thanks for all the help guys!
Re: put in new distributor, runs horrible [Re: MrBelvedere2] #1279582
08/06/12 08:57 PM
08/06/12 08:57 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
W H A T ???
