727 tranny fluid what you using #1279365
08/04/12 08:09 PM
08/04/12 08:09 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
getting ready to change the fluid and filter in my roadrunner its a street strip car 3500 stall shift kit deep pan,was wondering what others are using or recommending??been using valvaline.
Re: 727 tranny fluid what you using [Re: TB3CUDA] #1279366
08/04/12 08:14 PM
08/04/12 08:14 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I use dexron III in mine (what it says on the dipstick) Thought about using atf+4 but synthetic atf is one of the worst things to get off the track if something happens.
Re: 727 tranny fluid what you using [Re: MPerry] #1279367
08/04/12 08:32 PM
08/04/12 08:32 PM
NE Oklahoma
71valiant Offline
71valiant  Offline
NE Oklahoma
I'e always heard Dexron or type F. I also hear F makes it sift alittle harder, but that might be a myth.
Re: 727 tranny fluid what you using [Re: 71valiant] #1279368
08/05/12 12:27 PM
08/05/12 12:27 PM
Arizona
jsully Offline
jsully  Offline
Arizona
I bought a Hughes Tranny, when I picked it up they told me not to use Dexron, to use type F (or B&M non synthetic).
Re: 727 tranny fluid what you using [Re: MPerry] #1279369
08/05/12 01:36 PM
08/05/12 01:36 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I use dexron III in mine (what it says on the dipstick) Thought about using atf+4 but synthetic atf is one of the worst things to get off the track if something happens. [/quote/]
I use Dexron III also with good results.
