70 Challenger SE, slow return to the road #1279335
08/04/12 07:33 PM
08/04/12 07:33 PM
Jacksonville Fl
70BigBlockSE Offline OP
Jacksonville Fl
My parents purchased this Challenger from a small Dodge dealer in NW Iowa for $1600 in early 1978. The dealer was a relative of my father; he had bought the car out of the Des Moines Iowa area where it was for sale for parts! It started life as a JH29N0Bxxxxxx, the original 383 was gone but the transmission was still there. The fender tag and broadcast sheet survived, as did the car through my teenage years. In 1981 the car went into hibernation when I joined the Navy, finally in 2003 my Dad and I pulled it from his garage in NW Iowa and towed it to Florida. I've been retired since 2010 and finally made enough progress to post here.
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279336
08/04/12 07:35 PM
08/04/12 07:35 PM
Jacksonville Fl
Jacksonville Fl
Numbers: Sequence Number 2018048 VON 919023287
Broadcast Sheet info, pretty standard for a 70 SE. I read somewhere that 20% of 70 SE cars were FK5.
R11 V7X Y05 EN2
G33 L31 M21 M31 N41 N85
V1W A01 A62 C16 C26 C55
FK5 H5X9 000 919 023287
E63 D32 JH29 N0B xxxxxx
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279337
08/04/12 07:41 PM
08/04/12 07:41 PM
Jacksonville Fl
Jacksonville Fl
I guess I’ve changed some in 30 years, now I want a car that’s quick, but can also go around a corner and stop. SE rear window and vinyl top will go away. Adding a TA hood and rear spoiler, moving the antenna to the rear quarter.
Suspension Front and rear torque boxes, subframe connectors
Front 1 1/8” sway bar, 11.75” discs, Edelbrock Classic shocks, Flaming River 16-1 Manual box, lower control arm stiffeners, tubular upper control arms, 1” torsion bars, modern aluminum master cylinder, 11/16" tie rod ends & sleeves, Polygraphite front kit
Rear Firm Feel ¾” sway bar, Edelbrock Classic shocks, ESPO +1” arch springs, Doctor Diff 10.7″ rear disc brake kit and a 3.55 8 3/4”
Wheels and Tires American Racing Torq-Thrust II polished front 17x7, rear 17x8. Tires: Nitto NT 450 Extreme Performance 275/50R17 V Speed Rated, Nitto 555 Extreme 235/45ZR17 W Speed Rated
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279338
08/04/12 07:45 PM
08/04/12 07:45 PM
Jacksonville Fl
Jacksonville Fl
In June 2008 it went to Stripmasters in Milton FL, here's the goodbye picture.
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279339
08/05/12 12:28 PM
08/05/12 12:28 PM
Jacksonville Fl
Jacksonville Fl
Engine Muscle Motors pump gas 496 with Edelbrock Performer RPM Cylinder Heads. Camshaft is a Comp Cams XE284H-10 Hyd with duration at .050 of int 240, ext 246 and lifts int .507, ext .510 on a Centerline of 106. Intake Manifold is an Edelbrock Performer RPM it made 595hp at 5400rpm and 654tq at 4000. 32 degrees timing
Transmission Cope Racing Transmissions 727 ProStreet reverse manual shift with billet steel front drum and a 9.5 3200-3400 PTC torque converter
supposed to have color on it this weekend, can't wait it's been a long time.
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279340
08/05/12 09:49 PM
08/05/12 09:49 PM
Jacksonville Fl
Jacksonville Fl
let there be color!!!
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279341
08/09/12 01:32 PM
08/09/12 01:32 PM
Newark DE
Dogpro Offline
Dogpro  Offline
Newark DE
Looking good Now the fun part of putting it together.
Lou
Lou P.
Newark DE
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279342
08/09/12 02:45 PM
08/09/12 02:45 PM
Connecticut
jeff968 Offline
jeff968  Offline
Connecticut
We had a twin to your car in the late seventies except it was a 318 car. FK5, white top, burnt orange leather interior, SE. I still have the build sheet. I'm not an FK5 fan but it looks its best with a white top IMHO.
1970 Dodge Challenger T/A
Re: 70 Challenger SE, slow return to the road [Re: jeff968] #1279343
08/10/12 12:39 PM
08/10/12 12:39 PM
Jacksonville Fl
Jacksonville Fl
going to go with a white side strip like this. Toying with the idea of white seats.
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279344
08/10/12 02:21 PM
08/10/12 02:21 PM
TN
JS29R0B Offline
JS29R0B  Offline
TN
White interior and stripe will really set the car off!
Re: 70 Challenger SE, slow return to the road [Re: JS29R0B] #1279345
08/10/12 10:55 PM
08/10/12 10:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Looking nice. Another vote for white interior and stripes.
Sheldon
Re: 70 Challenger SE, slow return to the road [Re: RUNCHARGER] #1279346
10/09/12 03:00 PM
10/09/12 03:00 PM
Jacksonville Fl
Jacksonville Fl
Over the weekend I dropped off some parts at Stripmasters in Milton. They are showing my car as a rolling chasis at Garlits 3-4 Nov. Here's some new color pics
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279347
10/09/12 03:01 PM
10/09/12 03:01 PM
Jacksonville Fl
Jacksonville Fl
and the hood
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279348
10/09/12 03:05 PM
10/09/12 03:05 PM
Jacksonville Fl
Jacksonville Fl
and the engine, 110 cubes bigger than the original 383
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279349
10/09/12 06:22 PM
10/09/12 06:22 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Wow that looks GREAT
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279350
10/09/12 09:39 PM
10/09/12 09:39 PM
RUNCHARGER Offline
RUNCHARGER  Offline
That does look nice.
Sheldon
Re: 70 Challenger SE, slow return to the road [Re: RUNCHARGER] #1279351
10/11/12 06:50 AM
10/11/12 06:50 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Antenna hole is in the quarter panel like a TA?
Re: 70 Challenger SE, slow return to the road [Re: UCUDANT] #1279352
10/11/12 09:10 AM
10/11/12 09:10 AM
Jacksonville Fl
Jacksonville Fl
I had them move the antenna, going for look of a TA (sorta, hood, rear spoiler), stroker big block with better brakes and suspension than original. Interior will be all factory, extrerior parts are all original Mopar, just not on this car. Basically, how I would have built a Challenger.
Re: 70 Challenger SE, slow return to the road [Re: 70BigBlockSE] #1279353
10/11/12 09:30 PM
10/11/12 09:30 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Make sure to get the correct T/A antenna bezel. There is/was some confusion with a vendors stock
Re: 70 Challenger SE, slow return to the road [Re: UCUDANT] #1279354
10/21/12 12:08 PM
10/21/12 12:08 PM
Jacksonville Fl
Jacksonville Fl
getting closer, the engine installed, rolling on it's own wheels
