68 barracuda under dash courtesy light question #1279264
08/04/12 05:17 PM
08/04/12 05:17 PM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Hello, my barracuda was equipped with a courtesy light under the passenger side of the dash. Should it have one on the drivers side?
Also, does anyone know what type of screw holds the fuse block up. Mine is Mia. Thanks!
68 Barracuda Formula S 340
Re: 68 barracuda under dash courtesy light question [Re: Bad340fish] #1279265
08/04/12 06:08 PM
08/04/12 06:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
No. Just passenger side.
Re: 68 barracuda under dash courtesy light question [Re: Bad340fish] #1279266
08/05/12 09:19 PM
08/05/12 09:19 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The factory original is a Phillips oval machine screw 1/4-14 x 3/4 w lead point, phosphated. Oval means it is a countersunk screw with a domed top, similar to part B-13720 on page 121 here:
http://www.amkproducts.com/Catalog_PDF/109-127.pdf
Similar, meaning same head shape and same point, but diferent threads/inch, different size, different finish, and no washer.
