Re: 360 Magnum Balancing
[Re: Dan Halen]
#1279225
08/04/12 04:10 PM
08/04/12 04:10 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the magnum uses less external balancing weight then a LA 360, the pistons and rods are lighter. ...as said above use different damper and flexplate then a LA 360.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 360cuda]
#1279226
08/04/12 04:58 PM
08/04/12 04:58 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I put a late model damper and flex plate on the 360 Magnum I put in my '72 Charger.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: 360cuda]
#1279229
08/04/12 07:49 PM
08/04/12 07:49 PM
70AARcuda
las vegas
the rods are narrower on the small end where the pin goes thru...the magnums are less then an inch in width.
Tony
[Re: 360cuda]
#1279230
08/04/12 07:54 PM
08/04/12 07:54 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Looking at the rods isn't gonna tell you anything, instead look for any stamping on the crank that might be the record of a balance job. Otherwise I would just assume it's a stock Magnum and external balance accordingly.
