Re: Duel carb linkage question????????????????????? [Re: MRMOPAR622] #1279050
08/06/12 07:55 PM
08/06/12 07:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Go to your local boat parts supplier and get a Morse boat cable,they have them in just about any length you want.Plus they have a nut on the end to position it(like the Lokar) through the fire-wall.The plus to them is they have very strong cable,the negative is they need to be close to the correct length or a little longer if they need to make a bend,stay away from sharp bends and you can't beat them.
The bad part about the Morse cables is that they are
designed as a push/pull cable and are thicker in
diameter and are HARD to get any fairly tight radius...
they are great when you can have a BIG radius
Re: Duel carb linkage question????????????????????? [Re: MR_P_BODY] #1279051
08/06/12 08:44 PM
08/06/12 08:44 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Mr_P looking at the op carb. linkage,don't you think it would help most to turn the bottom arm on the linkage down like mine(its hard to see from picture I posted above)to straighten out the push-pull of the cable?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Duel carb linkage question????????????????????? [Re: MRMOPAR622] #1279052
08/06/12 08:55 PM
08/06/12 08:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd have to go back and look BUT you want it to start
just before 90* to the pulling force to give you the
least effort to the most distance of travel... the
ratios will dictate the amount of load against the
pulling force and then the return springs.. since
we HAVE to have 2 return springs AND the carbs already
have return springs you dont need much for the 2 returns
Re: Duel carb linkage question????????????????????? [Re: Clanton] #1279053
08/06/12 11:34 PM
08/06/12 11:34 PM
Great Neck,LI,new york
hemi-itis Offline OP
How is the carb linkage work coming?
Mike,the lokar will be in tomorrow.So depending how my phone rings tomorrow will determine how much time I can spend at the garage.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279054
08/06/12 11:46 PM
08/06/12 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL.... you do know those phones have a OFF button...LOL
Re: Duel carb linkage question????????????????????? [Re: MR_P_BODY] #1279055
08/07/12 12:36 AM
08/07/12 12:36 AM
My hours are 8 days a week , 30 hours a day!!
I', in the towing biz
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279056
08/07/12 09:04 AM
08/07/12 09:04 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I knew that!
Re: Duel carb linkage question????????????????????? [Re: Clanton] #1279057
08/07/12 11:15 PM
08/07/12 11:15 PM
The Lokar cable came in today.Real nice package that seems to come with all the needed hardware.The "L" bracket could be a little thicker
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279058
08/08/12 12:13 AM
08/08/12 12:13 AM
Cable with ends
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279059
08/08/12 09:45 AM
08/08/12 09:45 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Here is how mine looks.
Re: Duel carb linkage question????????????????????? [Re: Clanton] #1279060
08/08/12 09:46 AM
08/08/12 09:46 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
2
Re: Duel carb linkage question????????????????????? [Re: Clanton] #1279061
08/08/12 09:48 AM
08/08/12 09:48 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
3
Re: Duel carb linkage question????????????????????? [Re: Clanton] #1279062
08/11/12 10:44 AM
08/11/12 10:44 AM
Mike,I noticed the hole you use to attach to the carb is the lower one.I'm in the upper one,will that give a little more pull??I'm still short
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279063
08/13/12 04:59 PM
08/13/12 04:59 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
A few pics of a linkage that works. Perhaps they will assist you if you're still having issues with yours.
Re: Duel carb linkage question????????????????????? [Re: actionange] #1279064
08/13/12 05:01 PM
08/13/12 05:01 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Another
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279065
08/13/12 05:24 PM
08/13/12 05:24 PM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
Al, just a note of a problem we had with the braided cable. Since you have to use alot of pedal pressure it would cause the outer cable to pinch the inner one so the carbs didn’t
open all the way. We had to go to the black cable.
3 Darts and a Ram
Re: Duel carb linkage question????????????????????? [Re: hemi-itis] #1279066
08/13/12 05:53 PM
08/13/12 05:53 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That hole gives the correct ratio to open the blades all the way!The length from the pivot is kept the same on all.
