temperature guage #1278438
08/02/12 08:25 PM
08/02/12 08:25 PM
btomasko Offline OP
btomasko  Offline OP
Guage is at 845 position on dash,when grounded guage moves to hot but returns to 845 position on dash connectors have been checked even the limiter what could be the problem?any ideas thanks the fuel guage is working fine.
Re: temperature guage [Re: btomasko] #1278439
08/02/12 09:34 PM
08/02/12 09:34 PM
Andrewh Offline
Andrewh  Offline
like pegs to hot then drops?
when you unground and ground again, does it move? or does it take time before it will move again?
could just be a bad gauge.
take it out and put 2 AA batteries in series so they make 3 volts and hold it to the ends and see if it stays in the middle.
