Re: Dynomax 17784 Super Turbo drone
[Re: mnguy55]
#1278400
08/02/12 07:59 PM
08/02/12 07:59 PM
Posts: 3,149 Central NC
gch
Central NC
They can have a drone around 2000rpm.You can install two resonators in the tailpipes(a bullet muffler works good).
Otherwise you will lose flow or go to a louder muffler.
I think accurate ltd has a high flow muffler w/o the drone as well.Or the dynomax muffler with the flap inside that opens under pressure.
[Re: mnguy55]
#1278404
08/02/12 09:33 PM
08/02/12 09:33 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
never had a problem with Super Turbos droning.
Might want to double check the entire exhaust system routing and ensure nothing is rubbing and it is all isolated.
[Re: Supercuda]
#1278405
08/02/12 09:36 PM
08/02/12 09:36 PM
Posts: 4,848 Memphis
HemiRick
Memphis
My dynomaxs drone at idle in a 2.5 inch TTI x pipe system in an e body.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#1278406
08/02/12 09:49 PM
08/02/12 09:49 PM
RapidRobert
send em back & replace with a different type or easiest would be to add some glasspack/bullit type resonators alongside the leaf springs
[Re: Supercuda]
#1278407
08/02/12 10:34 PM
08/02/12 10:34 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
My big block Chevelle had a nasty drone and an ungodly rap accelerating...put a 1/2in open spacer under the carb and changed it all for the better....open the plenum up.
The little old lady from Pasadena is back!
