Valve Spring Compressor #1278393
08/02/12 05:45 PM
08/02/12 05:45 PM
London, England
mopar_mark Offline OP
London, England
Hi all,
I'm looking to buy a decent valve spring compressor, any recommendations, brands, etc,etc
Got to be able to use on Hemi heads, Stage V Engineering , etc
Thanks,
Mark ....
Re: Valve Spring Compressor [Re: mopar_mark] #1278394
08/02/12 06:11 PM
08/02/12 06:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Ive been real happy with my LSM compressor. I am doing a piddly little set of 80# 305 Chevy boat motor springs right now, and can go right to a set of blown alky 1400#springs and not miss a beat. A true bargain in my book.
RIP Monte Smith
Re: Valve Spring Compressor [Re: mopar_mark] #1278395
08/02/12 07:27 PM
08/02/12 07:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use these, the one on the left is nice and is very strong and simple, will never break.It has a double beam, I got this one from Wizards Racing.
Then the air one was built by Mike Troxel, Melanie Troxel/Johnson Dad. It's also bullet pruff but big bucks. Then one is for on the motor, then a homemade one and a spring tester is what the other ones are.
I also use one like this for on the motor, doesn't fit all heads, but is nice for changing springs on the motor in the car.
