Re: 440 oil filter question??? [Re: DPelletier] #1278216
08/02/12 11:02 PM
08/02/12 11:02 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
well as far as the brackets go, they are stock, i could have the wrong belt. What length belt should it be?
Re: 440 oil filter question??? [Re: mkbubs] #1278217
08/03/12 12:12 PM
08/03/12 12:12 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Don't have that info here at work; I'll try to remember to look when I get home.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440 oil filter question??? [Re: DPelletier] #1278218
08/03/12 01:10 PM
08/03/12 01:10 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I hope his question about the filter length was answered.
I want my fair share
Re: 440 oil filter question??? [Re: SomeCarGuy] #1278219
08/03/12 01:21 PM
08/03/12 01:21 PM
DPelletier Offline
DPelletier  Offline
No need to hope; just read the third post.
Re: 440 oil filter question??? [Re: SomeCarGuy] #1278220
08/03/12 01:38 PM
08/03/12 01:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The filter length isn't the problem.
I have seen a loose/too long power steering belt hit on the water pump pulley but never on the oil filter. . If you look at the picture posted above by DPelliter if the person has the correct parts it's kind hard to imagine the belt hitting the oil filter unless he has some enormous belt or the wrong setup ?
This is a case where not answering the question specifically is a good answer.
Re: 440 oil filter question??? [Re: JohnRR] #1278221
08/05/12 03:51 PM
08/05/12 03:51 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
so basically i need to get a shorter belt and that sould solve the problem?
Re: 440 oil filter question??? [Re: mkbubs] #1278222
08/05/12 04:27 PM
08/05/12 04:27 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Can you post some pics?
Re: 440 oil filter question??? [Re: mkbubs] #1278223
08/05/12 04:32 PM
08/05/12 04:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Hopefully
I am truckless..
Re: 440 oil filter question??? [Re: mopars4ever] #1278224
08/06/12 01:38 PM
08/06/12 01:38 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
ill take a picture tonight and hopfully post it either tonight or tomorrow.
Re: 440 oil filter question??? [Re: mopars4ever] #1278225
08/07/12 02:37 PM
08/07/12 02:37 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
here are a couple pics
Re: 440 oil filter question??? [Re: mkbubs] #1278226
08/07/12 04:05 PM
08/07/12 04:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Your fan belt is too long , you are out at the end of the adjustment slot.
Nevermind the cheap filter .
Re: 440 oil filter question??? [Re: mkbubs] #1278227
08/07/12 05:33 PM
08/07/12 05:33 PM
440dustr Offline
440dustr  Offline
not to change the subject but what are the numbers on the upper and lower radiator hoses that you used
thanks
Re: 440 oil filter question??? [Re: JohnRR] #1278228
08/07/12 10:41 PM
08/07/12 10:41 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
cool, thanks for the help guys. I guess thats what i get for going to the local auto parts store.??? Seems stuff from them is always a 50/50 shot whether it is going to work or not. As for the hoses, again O'reilly around the corner.
The number on the top hose is 20630 and the bottom is 20663, thought im not 100% the bottom one is the correct one. It seems a little long, i had to trim some off. Still a little long, but i'll deal with that when i get it close to running, which should be in a couple weeks hopefully.
Re: 440 oil filter question??? [Re: mkbubs] #1278229
08/20/12 10:00 PM
08/20/12 10:00 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
ok, i changed the belt, that didnt work. still rubbs the oil filter. not sure what else it could be. Maybe i need a smaller oil filter, wrong pully on the power steering pump, but that is the original one, i beleive. Or brackets on pump are wrong. ?????
Re: 440 oil filter question??? [Re: mkbubs] #1278230
08/21/12 11:35 AM
08/21/12 11:35 AM
scratchnfotraction Offline
you need a 2 groove wp pully so the ps belt goes from crank to wp to ps pump.
my 440 truck non a/c has it that way. 1 belt for ps and 1 belt to alt both on the same 2 groove wp pully.
in this pic it looks like it is touching the oil filter. but it is not.
Re: 440 oil filter question??? [Re: scratchnfotraction] #1278231
08/22/12 02:03 PM
08/22/12 02:03 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
cool thanks, i'll look into a new pully.
