Re: 440 oil filter question???
[Re: mkbubs]
#1278217
08/03/12 12:12 PM
08/03/12 12:12 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Don't have that info here at work; I'll try to remember to look when I get home. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: SomeCarGuy]
#1278220
08/03/12 01:38 PM
08/03/12 01:38 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I hope his question about the filter length was answered.
The filter length isn't the problem.
I have seen a loose/too long power steering belt hit on the water pump pulley but never on the oil filter. . If you look at the picture posted above by DPelliter if the person has the correct parts it's kind hard to imagine the belt hitting the oil filter unless he has some enormous belt or the wrong setup ?
This is a case where not answering the question specifically is a good answer.
[Re: mkbubs]
#1278222
08/05/12 04:27 PM
08/05/12 04:27 PM
Posts: 13,573 md
mopars4ever
md
[Re: mopars4ever]
#1278224
08/06/12 01:38 PM
08/06/12 01:38 PM
Posts: 61 Texas
mkbubs
Texas
ill take a picture tonight and hopfully post it either tonight or tomorrow.
[Re: JohnRR]
#1278228
08/07/12 10:41 PM
08/07/12 10:41 PM
Posts: 61 Texas
mkbubs
Texas
Your fan belt is too long , you are out at the end of the adjustment slot.
Nevermind the cheap filter .
cool, thanks for the help guys. I guess thats what i get for going to the local auto parts store.??? Seems stuff from them is always a 50/50 shot whether it is going to work or not. As for the hoses, again O'reilly around the corner. The number on the top hose is 20630 and the bottom is 20663, thought im not 100% the bottom one is the correct one. It seems a little long, i had to trim some off. Still a little long, but i'll deal with that when i get it close to running, which should be in a couple weeks hopefully.
