'72 340 cast crank engine flywheel question
#1277841
08/01/12 08:02 PM
08/01/12 08:02 PM
Posts: 2,512 God's Country Maryland
GODSCOUNTRY340
I've got a '72 340 with the cast crank going into my '72 340 4 speed Demon. Does this engine take a special flywheel? I know the steel crank 340 used a neutral balanced flywheel and the 360 used the cast crank flywheel and are not interchangeable. Can I use the 360 flywheel on this engine or is there a different one for the cast crank 340? Thanks
Re: '72 340 cast crank engine flywheel question
[Re: GODSCOUNTRY340]
#1277842
08/01/12 09:31 PM
08/01/12 09:31 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Different flywheel for the 72/73 cast crank 340 . I had a 318 flywheel rebalanced for my 73 340...
I am truckless..
[Re: John_Kunkel]
#1277845
08/02/12 04:52 PM
08/02/12 04:52 PM
GODSCOUNTRY340
Thanks a million John. After looking at your diagram I check through my stash and found this flywheel. The number isn't in my interchange book but it sure looks like the one diagramed. What do you think? 2264598
#1277847
08/08/12 05:23 PM
08/08/12 05:23 PM
Posts: 25,808 Rio Linda, CA
John_Kunkel
Rio Linda, CA
2264598 is the casting number, it was used on all 130-tooth installations from '62 into the nineties....the various external balance configurations gave it a different part number but the casting number stays the same.
That looks like the correct one for a cast crank 340.
