Re: Gear Vendored 727 and a sure grip
[Re: roadrunninMark]
#1277427
08/01/12 09:48 PM
08/01/12 09:48 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Oh,, a 4 planetary unit stronger than a 3 planetary unit. Id highly suggest a bolt in sprag. Use a clutch style suregrip unit..
I am truckless..
[Re: torqueaddict]
#1277429
08/02/12 12:54 PM
08/02/12 12:54 PM
dogdays
4 pinions are stronger than 3, 5 are stronger than 4! The bolt-in sprag is a good idea, as is a billet drum (so I've heard).
The Gear Vendors unit doesn't decrease the load on the transmission, so transmission strengthening is still a good thing.
You need to find pictures of the two different Sure Grip units and look at what you have. If it's a 489 case, it should have the cone type, if a 742 case it should be the clutch type and if it's a 741 it could be either. And, of course, anything could have been swapped into any case over the last 40 years!
Can you swap your 3.23s for 4.11s? Sure, this is a job for a rear end specialist, but it's done all the time. The 3.91 gearset seems to be the most popular.
R.
[Re: John_Kunkel]
#1277433
08/02/12 06:46 PM
08/02/12 06:46 PM
Posts: 3,437 Dandridge TN
Dabee
Dandridge TN
Not necessarily true...the weak part of any aluminum planetary is the spline, not the pinion count.
I have a 727 equipped GV behind my 511 stroker. My 727 has the three pinion gear, bolt in sprag and a reverse manual VB. I also run a Dana. I have had no problems with my set up.
[Re: John_Kunkel]
#1277434
08/03/12 01:33 AM
08/03/12 01:33 AM
Posts: 6,563 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
My trans guy used to race a AA/SS Hemi Cuda and they used to take out 2 of the 4 pinions to reduce rotating weight. Never broke a pinion but splines?...
Kevin
