Re: Tire Shake Problem
[Re: jamesc]
#1277267
07/31/12 10:59 PM
07/31/12 10:59 PM
Posts: 1,443 Maryland
Dads426
Maryland
u running tubes?
Yes. Hoosier doesn't make a stiffer sidewall (they suggested a shorter tire and I don't want to do that due to the finish line rpms). Goodyear? M/T? Phoenix?
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: MR_P_BODY]
#1277270
08/01/12 02:32 AM
08/01/12 02:32 AM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
IMO in that size tire M/T prety much rules the roost. We run the M/T stiff sidewayy 29.5x10.5 tire on the heads up car. Do you have video of what is happening? Be interested in seeing what you have going on.
[Re: Al_Alguire]
#1277271
08/01/12 08:20 AM
08/01/12 08:20 AM
Dads426
Maryland
We balance them when they are mounted. There is no vibration at speed. There is a Hoosier dealer nearby, so they install and balance for free. Don't have good video of the car when this occurs. I watch it at launch and do not notice any shake. Wondering why running tubeless will help? May look at the M/T tires for next season. Will probably throw on a new set of Hoosiers this Friday since we are at Maple Grove this weekend.
[Re: Dads426]
#1277272
08/01/12 01:26 PM
08/01/12 01:26 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
Usually, when we go into tire shake (nitrous cars though). We just through a little more power at it sooner to eliminate the tire shake. It will cause a little more tire spin but not going up in smoke unless on a marginal track.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#1277274
08/01/12 05:24 PM
08/01/12 05:24 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
This may not help as I have a dragster and run big tires,but I took the tubes out and left all the screws out as well and the tire shake went away.The man that told me to try that said if I wanted to keep the tubes I would have to put about 18 screws per side. You may want to try it with out the tubes and screws,won't take much time or $$$ to try. PS I marked the tires at the valve stem and they have not moved.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
