Re: TTI exhaust
[Re: NortheastMopar]
#1277003
07/31/12 11:17 AM
07/31/12 11:17 AM
Posts: 2,200 Sec.414,seat 12,White Sox Park
swapman
I bought a 3 inch set of Hemi manifold to tips from Mancini Raceing. A word of caution. Do not make the same mistake I made, buying before needed. When the year finally came (and I do mean year) to install them, I found out that almost nothing fit. Needed to cut and weld channels in the pipe for torsion bar clearance. The ends of the overaxle pipe did not come close to the valance. Needed to porta power the angles back from tranny. Needless to say, much cutting and rewelding, then recoating. I had enuff time and $'s in them to buy 3 sets. The stuff works, but you need to test fit immediatly after purchase or you are on your own. This has happened with other parts as well. The return policys are all over the place. So much for accumalating parts thru the years. ![](/ubbthreads/images/graemlins/Twocents.gif) P.S. The only exhaust system I have seen that fit 1st time everytime, were the pipes from Accurate LTD. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: TTI exhaust
#1277005
07/31/12 11:50 AM
07/31/12 11:50 AM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
My TTI system fit like a glove; I trimmed about an inch off my H pipe, otherwise it went together like LEGO ![](/ubbthreads/images/graemlins/thumbs.gif) ...the accurate stuff is good as long as you don't mind the lower performance, compression bends. ![](/ubbthreads/images/graemlins/Twocents.gif) Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: TTI exhaust
[Re: DPelletier]
#1277008
07/31/12 12:58 PM
07/31/12 12:58 PM
I have three TTI exhaust systems, and one Accurate LTD. All four fit like a glove. Every now and then I hear someone complain about TTI, but so far I've not had a problem.
Re: TTI exhaust
#1277009
07/31/12 01:59 PM
07/31/12 01:59 PM
DPelletier
in the interest of full disclosure, my TTI system was a 2.5" with H pipe using factory HP manifolds and their stainless tips.
1974 'Cuda
Re: TTI exhaust
[Re: Charger727]
#1277012
07/31/12 02:57 PM
07/31/12 02:57 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
I bought my headers many years ago(at least 10)They hung in the garage foe 3years or more until I ordered the rest of the 2.5" system.When I went to install the system,nothing lined up.The only thing I could figure was I was gonna have to cut the headers apart and reweld them to fit.I hadn't kept my reciept but I decieded to call TTi to get some advice on cutting and welding.I was very politely told to package them up and send them back and they would reweld if needed.The only cost to me was what it cost to ship them.I shipped them out and with in a week Sam called and explained that I had an early set and there were some changes to later headers.He asked what size collectors I was useing and sent me a new set of headers and collectors.They even picked up the return shipping.The new set fit without any issues,no hammering,bending or cutting. I don't know who will give you the best price,but I know their customer service is great.If you have any fitment issues call them BEFORE you hammer,cut or bend
This would be so much easier if I knew what I was doing...
Re: TTI exhaust
[Re: Polarabill]
#1277013
07/31/12 08:12 PM
07/31/12 08:12 PM
Posts: 1,730 elyria, ohio
72gtx4speed
elyria, ohio
i bought mine from mancini at last years nats. they have been collecting dust since then. i will be installing them in the next couple weeks so i hope they fit without problems. mancini had a special which basicly covered shipping.
clem
when i grow up i want to be just like sunroofgtx, god please don't let me grow up.
Re: TTI exhaust
[Re: Polarabill]
#1277015
07/31/12 09:33 PM
07/31/12 09:33 PM
A friend of mine who has two sets of A body TTI tailpipes made several years apart says they are different - they don't run in quite the same place or exit in the same place. Apparently TTI makes running changes every now and then. That might possibly explain why some of you who bought part of the system one year, and then several years later the rest, had problems. ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: TTI exhaust
#1277018
08/01/12 11:33 AM
08/01/12 11:33 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
In 2006 I bought TTi tailpipes for my 69 Dart , HUGE waste of money , the did not exit in the stock location and require the mufflers not be mounted from the factory hanger location ...
