Page 1 of 3 1 2 3
Strange oil pressure problem #1276924
07/31/12 01:46 AM
07/31/12 01:46 AM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
Working on a customers car and it has oil pressure fits. When it reads no oil pressure it has none(at the guage port with the line off).
Eliminate the guage , oil pump (melling HV cast iron style) , bypass , guage lines , oil filter as they have all been tried to death. Oil pickup is in good shape and away from the bottom of the pan. Oil level is correct. Has 1/2" pickup in a standard center sump pan (7qt).
Its a 440 and when you start the motor it will be fine and the oil pressure will be fine until you turn the car off. The next startup it will have no oil pressure even if you rev it. Simply shut the car off and restart (some times 2 or 3 times) and its fine. It goes from 80 psi to zero then corrects itself right back to 80 again on a restart. Sometimes its fine for many restarts. There is no pattern to this.
Im puzzled and its wearing me out. No metal in the oil , pan has been off and its clean.
Any ideas before I tear it all apart?
Hutch
Re: Strange oil pressure problem [Re: Hutch] #1276925
07/31/12 01:53 AM
07/31/12 01:53 AM
Pull the bypass valve plug, spring and piston out and clean them up, do the hosuing bore also It, the valve and piston, needs to slide in and out with no tapping or forcing, I've seen that in the past . One sure way of telling is to remove the pump and bypass plug and turn the pump so the bypass valve and piston are pointing down, if the piston slides out and the valve stays in the pump housing clean it out It only takes a tiny bit of grit between the pump housing and valve to make it hang up in the bypass position, especailly when new
Re: Strange oil pressure problem [Re: Cab_Burge] #1276926
07/31/12 02:08 AM
07/31/12 02:08 AM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
Done all that. Even installed another pump. Same deal. The press reg valve has no scratches on it or has it ever nor has it ever been stuck in the bore.
Hutch
Re: Strange oil pressure problem [Re: Hutch] #1276927
07/31/12 02:57 AM
07/31/12 02:57 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Pull the oil pump drive shaft..
Some drive gears were not pinned and can work loose, making unreliable operation..
Just my $0.02...
Re: Strange oil pressure problem [Re: Sinitro] #1276928
07/31/12 12:37 PM
07/31/12 12:37 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Just my $0.02...
it could be the pump drive but not for the reason you mentioned. if the gear were to turn on the shaft the engine would lose time, check the condition of the hex on the shaft
Re: Strange oil pressure problem [Re: jamesc] #1276929
07/31/12 12:41 PM
07/31/12 12:41 PM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
Just changed the drive only because the old brass gear drive was wearing excessively. Did it with both drives for what its worth.
Hutch
Re: Strange oil pressure problem [Re: Hutch] #1276930
07/31/12 01:33 PM
07/31/12 01:33 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Spinning bearing?
Re: Strange oil pressure problem [Re: sshemi] #1276931
07/31/12 01:38 PM
07/31/12 01:38 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Sounds like an air leak in the suction side. I would look for a crack or bad seal at the pipe thread end. Also what lifters are in it? I have seen the dumbell shaped lightweight solids cause oil pressure problems.
Re: Strange oil pressure problem [Re: Hutch] #1276932
07/31/12 01:43 PM
07/31/12 01:43 PM
jamesc Offline
jamesc  Offline
internet troubleshooting is never easy and it seems like you've been through this pretty thoroughly. that said it really sounds like the pump is losing prime. i would think even with the relief stuck open some it would still push some oil out the pressure port. oiling systems aren't very complicated so unless it's some bizarre problem it has to be something you've already looked at. i would concentrate on the suction side of the pump and that's a pretty straightforward setup. being it sounds like such a weird problem maybe using a drill and priming drive might be worth a shot to see if you can duplicate the problem without running/cycling the engine.
Re: Strange oil pressure problem [Re: jamesc] #1276933
07/31/12 01:45 PM
07/31/12 01:45 PM
jamesc Offline
jamesc  Offline
you would think if it was some sort of bearing problem it would show in other ways. i'm assuming this is a roller being he mentioned the bronze drive gear.
Re: Strange oil pressure problem [Re: Hutch] #1276934
07/31/12 01:52 PM
07/31/12 01:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How much pressure does it start out with when cold
Re: Strange oil pressure problem [Re: Hutch] #1276935
07/31/12 03:00 PM
07/31/12 03:00 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
Hutch
Pump is losing prime for some reason. I used to see this on my 496 wedge when I changed the oil. As soon as I took the filter off, the pump wouldn't prime. I had to spin the drive in reverse and squirt oil into the hole in the pump next to the threaded nipple.
Re: Strange oil pressure problem [Re: Hutch] #1276936
07/31/12 03:09 PM
07/31/12 03:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I seen this on my Jeep 4.0... it was excessively worn
bearings... when the oil heats up the pressure would
drop to almost 0... I changed the bearings and pump
and its fine now
Re: Strange oil pressure problem [Re: MR_P_BODY] #1276937
07/31/12 06:01 PM
07/31/12 06:01 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
You mentioned roller cam what lifters are you using and are the lifter bores bushed?
Todd
Re: Strange oil pressure problem [Re: sasquatch] #1276938
07/31/12 08:48 PM
07/31/12 08:48 PM
Ontario Canada
Hutch Offline OP
Hutch  Offline OP
Ontario Canada
No problem in the suction side. Keep this in mind. It doesn't lose oil pressure and it doesn't loose its prime. It either has it or it doesn't.
It will go from having perfect oil pressure then you shut the car off and start it right back up and it has zero. shut it off and start it right back up and it goes back to 60-80 depending on temperature.
I drove it 50 miles , shut it off for gas , started it up and it had zero. shut it off , started it again , back up right where it left off and I drove it all around until the next time I shut it off.
Its just stupid.
Hutch
Re: Strange oil pressure problem [Re: Hutch] #1276939
07/31/12 08:53 PM
07/31/12 08:53 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Did you try a different gauge?
Re: Strange oil pressure problem [Re: Hutch] #1276940
07/31/12 08:53 PM
07/31/12 08:53 PM
Arizona
Chris'sBarracuda Offline
Arizona
Bad Gauge?
Chris..
Re: Strange oil pressure problem [Re: Hutch] #1276941
07/31/12 08:56 PM
07/31/12 08:56 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Have you pulled the valve covers. maybe has a bent pushrod allowing the lifter to be kicked up high enough to uncover the oil galley but unlike a flat tappet which usually kicks them right out it would be held somewhat in place by the link bar and drop down into place eventually??
Just a thought??
Re: Strange oil pressure problem [Re: Hutch] #1276942
07/31/12 09:05 PM
07/31/12 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its just stupid.
Hutch
That is a weird one.. hope you find it soon
EDIT
Just thinking... is the intermediate shaft long
enough so it isnt jumping up on start up and spinning
on top of the pump spline then when you shut it off
it drops in
Re: Strange oil pressure problem [Re: MR_P_BODY] #1276943
07/31/12 09:33 PM
07/31/12 09:33 PM
jamesc Offline
jamesc  Offline
i'm trying to recap according to the OP
Gauge, he says when it loses pressure it won't even pump oil out the pressure port.
Bearings, if something is a problem bearing wise any engine that would go from 80# to 0 is going to show it some other way.
Pump drive, said it's been replaced
Pump, it's been replaced and they've been disassembled and inspected
Filter, been replaced
Lifters, if it was uncovering the galley it shouldn't come and go. if it had a bent or displaced pushrod the engine should show a problem by being noisy or running rough
though i've never seen it happen i guess it could be possible the inner rotor is spinning on the drive stem but OP says the pumps have been inspected and if this was happening you'd think it might show metal in the oil although anything from that should go through the filter
now just to make sure i'm understand you correctly it not only loses pressure intermittently on a restart but also when it's been running it will lose pressure while running?
starting to sound like you need to call Father Merrin
Page 1 of 3 1 2 3
