Mini starter on a BB #1276833
07/30/12 09:25 PM
07/30/12 09:25 PM
Y
Yatzee Offline OP
Yatzee  Offline OP
Y
Has any one found a brand of mini starter that dose not cost a fortune,
mounts correctly and works to crank a BB with 10:1 compression? All I've
heard are nightmares about failure, overheating, mounting issues and
terminals that are too close to the block. I have a 383 with a TTI header/exhaust system hung on it and messing with starter swapping is
a real issue I wish to avoid.
Re: Mini starter on a BB [Re: Yatzee] #1276834
07/30/12 09:30 PM
07/30/12 09:30 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
The electrical section of the tech archive has some good information on the subject.
Re: Mini starter on a BB [Re: bobby66] #1276835
07/30/12 09:36 PM
07/30/12 09:36 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I used the one from DB Electrical. Works nice and spins the motor over fast. The terminals are close to the block but not touching. I just hooked up the wires first then mounted the starter.
Scott
1969 Super Bee, 383/4 speed
Re: Mini starter on a BB [Re: StukaJU87] #1276836
07/30/12 10:04 PM
07/30/12 10:04 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I have a NAPA starter for a 93 V8 Dakota.Was around $100 brand new not reman. Need to remove the terminal adapter, no biggie. Clears my CPPA(similar to TTI)headers and spins my 10:1 470" easily for over 3 years now.
Re: Mini starter on a BB [Re: Yatzee] #1276837
07/30/12 10:42 PM
07/30/12 10:42 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have the used stock starter from a 87 5.9 truck on my 451 stroker now with TTI headers. Fits and works great.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Mini starter on a BB [Re: HemiRick] #1276838
07/30/12 10:59 PM
07/30/12 10:59 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have one from an early 90's ram van. I can't totally remember, but I may have had to grind down the main power terminal stud a little for block clearance.
Re: Mini starter on a BB [Re: StukaJU87] #1276839
07/30/12 11:07 PM
07/30/12 11:07 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I have a DB starter too, I think it was 75 bucks or something, works awesome! Egag!!
CrAzYMoPaRGuY
Re: Mini starter on a BB [Re: CrAzYMoPaRGuY] #1276840
07/31/12 04:04 AM
07/31/12 04:04 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Re: Mini starter on a BB [Re: StukaJU87] #1276841
07/31/12 06:50 AM
07/31/12 06:50 AM
Rochester, NY
Red63440 Offline
Red63440  Offline
Rochester, NY
X2
68 Barracuda Fastback
Re: Mini starter on a BB [Re: StukaJU87] #1276842
07/31/12 09:14 AM
07/31/12 09:14 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
i have the one from db elect also 10 years no problems
Re: Mini starter on a BB [Re: BIGSTROKER] #1276843
07/31/12 12:53 PM
07/31/12 12:53 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I used one off a '98 Dakota, had to cut about 1/2" off the positive stud. Way better than the 40-yr-old boat anchor. I had to mount the wires first as well, then I found that some of the racing starters come with an adapter bracket to move the studs away from the block. Couldn't find the adapter for sale anywhere, but a friend had a spare one and gave it to me.
Re: Mini starter on a BB [Re: Yatzee] #1276844
07/31/12 02:09 PM
07/31/12 02:09 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
I used the mini starter from 440 Source. I read comments about the terminals being too close to the block but I did not have a problem with that issue. I had more of a problem getting the starter on the block with the headers in the way.
Re: Mini starter on a BB [Re: StukaJU87] #1276845
07/31/12 03:18 PM
07/31/12 03:18 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ditto,
I've used 2 from them.
1 on a 484 hemi and the 2nd on a essentially stock 440 . both fit and worked perfect.
http://www.ebay.com/itm/NEW-MINI-MOPAR-D...=item1e67a4f65a
Re: Mini starter on a BB [Re: gtx6970] #1276846
08/01/12 12:09 AM
08/01/12 12:09 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
how far are the studs from the block?
Ditto,
Re: Mini starter on a BB [Re: dangina] #1276847
08/01/12 07:11 AM
08/01/12 07:11 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a reman one for a 99 Durango 360 on my 440 with 12.5 pistons.Its been in for probally 15 years.Had to cut about 1/4 inch to have a lot of clearance to the block.My kid used a 440 Source one on his 413.Went right in and been fine for 4 years.Both have headers.Rocky
Chrysler Firepower
Re: Mini starter on a BB [Re: therocks] #1276848
08/03/12 02:26 AM
08/03/12 02:26 AM
Central TX
roe Offline
roe  Offline
Central TX
I have a new one for a mid 90's pickup from Autozone. Ditto what they said on removing the plastic terminal and then your stock cables bolt right up, just connect them before you mount it. I like the nationwide, no questions asked, no receipt necessary, free replacement for life at any Autozone if it ever fails.
Roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Mini starter on a BB [Re: Yatzee] #1276849
08/03/12 09:17 PM
08/03/12 09:17 PM
tucson az
frank Offline
frank  Offline
tucson az
I used the 440 source mini. I took it to the parts store and compared it to the v6 dak starter. They were identical. You could not tell the difference by looking at them. The v6 dak starter from Auto Zone was about $60 with a lifetime warranty. The 440 source starter fit fine on my RB. You need to hook the wires up first.
Re: Mini starter on a BB [Re: frank] #1276850
08/04/12 07:08 AM
08/04/12 07:08 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Got mine from Mancini at the Chrysler Classic one year. Don't remember what it cost. I do know I didn't pay any shipping! Had one on both a small block and a big block and both had headers. The big block has tti.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Mini starter on a BB [Re: OhioMopar] #1276851
08/04/12 08:33 AM
08/04/12 08:33 AM
tboomer Online work
tboomer  Online Work
Bought my mini out of a junkyard for 25.00...Spins my 13.4-1 512" RB over pretty good!!
Re: Mini starter on a BB [Re: tboomer] #1276852
08/04/12 02:29 PM
08/04/12 02:29 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Thats what I have always used. They have plenty of power. I just put a fresh set of contacts in them and go. Just get one off any 94-up mag motor. The earlier non mag starters will work also but are a tad bigger.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
