Recommend me a tire size! #1276750
07/30/12 05:53 PM
07/30/12 05:53 PM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
Using 15x7 cop car rims on my car (using '70 Rallye centers and trim rings).
I was thinking 245/60/15 fronts and 255/60/15 rears.
The car will be about 1.5" lower than stock.
Anyone?
-Jarrod Pilone
'70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit)
My Project Thread
Re: Recommend me a tire size! [Re: jpilone] #1276751
07/30/12 06:22 PM
07/30/12 06:22 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Way to small try 225/70/15 front and 275/60/15 rear.
Re: Recommend me a tire size! [Re: jpilone] #1276752
07/30/12 06:54 PM
07/30/12 06:54 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i've said it before and i'll say it again - that friggin bug gets me every time!
Re: Recommend me a tire size! [Re: moparpollack] #1276753
07/30/12 08:03 PM
07/30/12 08:03 PM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
275's aren't too wide for the 15x7 cop car rims?
-Jarrod Pilone
My Project Thread
Re: Recommend me a tire size! [Re: jpilone] #1276754
07/30/12 08:09 PM
07/30/12 08:09 PM
85086
Lil Herman
Lil Herman
85086
Try 255/70/15 they are decent also.
Re: Recommend me a tire size! [Re: jpilone] #1276755
07/30/12 11:06 PM
07/30/12 11:06 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
A bunch of people will tell you that a 275/60 is too wide for a 7 inch wheel, but i have run them for 10 years on 7 inch ralleys on a 73 RR. They look and drive fine. I agree that an 8 to 10 inch wheel would be better suited, but these are what i had and a smaller tire looks wimpy on a B body. If you want something narrower, go with a 70 series so at least you have some height to fill the wheel opening.
Re: Recommend me a tire size! [Re: forphorty] #1276756
07/30/12 11:11 PM
07/30/12 11:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Would a 275/60 even fit properly on a 10" rim? 10" is a wide rim and a 275/60 isn't that wide of a tire. I've run 275/60's on a 7" rim for years. No problems, no weird tread wear, get a clean patch of rubber when I
Re: Recommend me a tire size! [Re: jpilone] #1276757
07/31/12 12:45 AM
07/31/12 12:45 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Go 225 or 235/70 on the front. I just mounted up some 245/60's on my 69 GTX front and not real keen with it. For the rear, go for the 275/60's.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Recommend me a tire size! [Re: jpilone] #1276758
07/31/12 12:47 AM
07/31/12 12:47 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Whoa! LONG time since I've seen your name! welcome back!
Re: Recommend me a tire size! [Re: Kern Dog] #1276759
07/31/12 08:55 AM
07/31/12 08:55 AM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
Thanks! As usual with me, life gets in the way with my project. This time, hopefully, I'll get it done finally.
So the general consensus is 235/70 front and 275/60 for the rears
Some BFG's will be on order today or tomorrow from tirerack.
-Jarrod Pilone
My Project Thread
Re: Recommend me a tire size! [Re: jpilone] #1276760
07/31/12 12:40 PM
07/31/12 12:40 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I once tried mounting a 235-70-15 on a 15x7 rally on my 70 Road Runner and it was too big in diameter and rubbed the fender at the front of the wheel opening. Do you think a 235-70-15 would fit without rubbing if maybe a 6" wide wheel or a 15x7 wheel with different rear backspacing than that of a factory rally were used?
Re: Recommend me a tire size! [Re: DaytonaTurbo] #1276761
07/31/12 03:32 PM
07/31/12 03:32 PM
California
mickm Offline
mickm  Offline
California
i run them on a 10" rim, no problems. only issue is that i can't get a 295 under there, as the 10" rim balloons out the sidewall. it doesn't look bad, and isn't noticeable, but it is out far enough on the 10" rim that a 295 won't go.
i recently ran into a 70 with 275/60's on an 8" rim, and the difference in room under there was amazing. i'm going to go with a 295/55 on an 8" rim, and that should get me the extra tire under there.
Re: Recommend me a tire size! [Re: mickm] #1276762
07/31/12 10:39 PM
07/31/12 10:39 PM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
what about a 255/60/15 front and 275/60/15 rear? That's about a 27.5" front and near 28" rear I think...
-Jarrod Pilone
My Project Thread
Re: Recommend me a tire size! [Re: jpilone] #1276763
08/01/12 01:00 AM
08/01/12 01:00 AM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
That's what I have on my car right now!
Re: Recommend me a tire size! [Re: Airgrabber] #1276764
08/01/12 03:01 AM
08/01/12 03:01 AM
Manitoba, Canada
Manitoba, Canada
Just for reference, here's a side shot of my car with a 235/60 up front and a 275/60 out back. I don't think I'd want to go up much in diameter on the front tire.
Re: Recommend me a tire size! [Re: DaytonaTurbo] #1276765
08/01/12 08:08 AM
08/01/12 08:08 AM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
Looks "just right" to me!
-Jarrod Pilone
My Project Thread
Re: Recommend me a tire size! [Re: Airgrabber] #1276766
08/01/12 08:08 AM
08/01/12 08:08 AM
Boca Raton, Florida
jpilone Offline OP
jpilone  Offline OP
Boca Raton, Florida
Show us a pic!
-Jarrod Pilone
My Project Thread
Re: Recommend me a tire size! [Re: jpilone] #1276767
08/01/12 08:18 AM
08/01/12 08:18 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I think your going to have a hard time getting a 275-60-15 on an 8" rim under the car if the chassis is lowered and not have it rub,
UNLESS you play with the offset of the wheel.
Personally if the car is lowered I would stay witha 255 on a 7" rim
Re: Recommend me a tire size! [Re: gtx6970] #1276768
08/01/12 12:13 PM
08/01/12 12:13 PM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
jpg[/image]The ragtop has 255/60-15 on all 4. The other two had 235/70-15 15x7 front and 275/60-15 rear.
Re: Recommend me a tire size! [Re: DaytonaTurbo] #1276769
08/01/12 01:08 PM
08/01/12 01:08 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
275 stands for 275mm tread width or 10.82" so yes, it'll fit on an 10" rim. Recommended rim size is 7.5" - 9.5" so 8" rims are the right choice but obviously 7" or 10" still works.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
