Fuel Pump mounting. Stock tank-Pictures #1276526
07/30/12 10:29 AM
07/30/12 10:29 AM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
I wanted to see where to locate a electric fuel pump with a stock tank. Holley wants it below the tank but that would be difficult. My car originally had it above the tank and its mounted horizontally no less and worked. I just upgraded to 1/2" and now it wont pull. Just looking for ideas where to mount.
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: Fuel Pump mounting. Stock tank-Pictures [Re: 65 NSS 500] #1276527
07/30/12 02:28 PM
07/30/12 02:28 PM
Northampton Pa
Northampton Pa
Re: Fuel Pump mounting. Stock tank-Pictures [Re: 65 NSS 500] #1276528
07/30/12 07:52 PM
07/30/12 07:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a stock tank and sending unit but I did put a 3/8 sending unit in with the stock float so my gas gauge still works good. I run a Firecore 140 pump and actually have it mounted in front of the tank bolted to the floor between the shocks. Been there for years with no problem at all. I would think you will have to use a frame rail to try and get the pump below or even with the stock tank as I plan to do that later. Ron
Re: Fuel Pump mounting. Stock tank-Pictures [Re: 65 NSS 500] #1276529
07/30/12 09:07 PM
07/30/12 09:07 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I mounted mine between the back of the tank and the frame rails. Really tight fit, but makes it really clean too as the valance panel covers it up. I ran the 3/8 stock pick up but added another 3/8 line for the 2nd pump. Never had an issue with fuel starvation using stock tank.
Old Geezer Racing
Re: Fuel Pump mounting. Stock tank-Pictures [Re: SCATPACK 1] #1276530
07/30/12 09:16 PM
07/30/12 09:16 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
On my old 64 Plymouth it was mounted just above the rear. You can see the 3-point mounts in the right side of the trunk (don't have an underside pic). We had a stock tank with a Carter electric pump mounted on the supplied "L" bracket.
Re: Fuel Pump mounting. Stock tank-Pictures [Re: 65 NSS 500] #1276531
07/30/12 09:28 PM
07/30/12 09:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You SHOULD have it mounted low and at the rear of the
tank... remember that its atmospheric pressure thats
pushing the fuel in so if its up high you need to have
a high level of fuel to prime it
Re: Fuel Pump mounting. Stock tank-Pictures [Re: MR_P_BODY] #1276532
07/30/12 09:46 PM
07/30/12 09:46 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
On a racecar. Ours was a street/strip car like Ron's and if I remember correctly the stock pickup was at the front of the tank which made it easy to connect to the fuel pump near the shock mount. On our present car the pump is in the tank with a rear pickup.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
