Lets see your oil accumulator mounts! #1276129
07/29/12 07:04 PM
07/29/12 07:04 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I think I need one, and I think I am going to mount it the drivers side of my engine plate, but want to your mounts and best hiding spots.
Re: Lets see your oil accumulator mounts! [Re: Dragula] #1276130
07/29/12 07:15 PM
07/29/12 07:15 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
This was easy location.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Lets see your oil accumulator mounts! [Re: Dragula] #1276131
07/29/12 08:57 PM
07/29/12 08:57 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
here is a photo with the bumper removed, mine is electric, I love them.
Joey
Re: check this out.... [Re: Dragula] #1276132
07/29/12 09:38 PM
07/29/12 09:38 PM
PA
Z
zooom Offline
zooom  Offline
Z
PA
Mine fits neatly on the pass. side of my R3 block under the headers & is hard-line plumbed to the 90* oil filter adaptor. Works great & is out of the way for normal maintenance.....
Re: check this out.... [Re: zooom] #1276133
07/29/12 10:04 PM
07/29/12 10:04 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
That looks good but I done see a valve anywhere,so I assume you don't use it as a preoiler also.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Lets see your oil accumulator mounts! [Re: Dragula] #1276134
07/29/12 11:01 PM
07/29/12 11:01 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Here it is,drivers side engine plate.
Doug
Re: Lets see your oil accumulator mounts! [Re: dvw] #1276135
07/29/12 11:05 PM
07/29/12 11:05 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
One more. This was during mock-up. I didn't like the clamps. The new ones came from Summit. $17 for the pair.
Doug
Re: Lets see your oil accumulator mounts! [Re: dvw] #1276136
07/29/12 11:07 PM
07/29/12 11:07 PM
skelator Offline
skelator  Offline
could you guys please school me on the function of accumulators? should everyone have one?
Re: Lets see your oil accumulator mounts! [Re: skelator] #1276137
07/29/12 11:19 PM
07/29/12 11:19 PM
hemi-itis Offline
hemi-itis  Offline
http://www.moroso.com/catalog/categorydisplay.asp?catcode=13600
Take a look.
Re: Lets see your oil accumulator mounts! [Re: skelator] #1276138
07/29/12 11:20 PM
07/29/12 11:20 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
here is mine behind the grill
Re: Lets see your oil accumulator mounts! [Re: MOPARCHAS] #1276139
07/29/12 11:24 PM
07/29/12 11:24 PM
Arizona
Chris'sBarracuda Offline
Arizona
Re: Lets see your oil accumulator mounts! [Re: Chris'sBarracuda] #1276140
07/30/12 12:53 AM
07/30/12 12:53 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
clamped to the front bar was my option, it doesn't get hit with anything thats likely to cause damage & fail.
Re: Lets see your oil accumulator mounts! [Re: rebel] #1276141
07/30/12 02:11 AM
07/30/12 02:11 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Drivers side front bar of cage. I machined aluminum brackets that clamp to the bar and used the moroso clamps to attach the accumulator to them. Beep
Re: check this out.... [Re: zooom] #1276142
07/30/12 05:27 AM
07/30/12 05:27 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
older pic! gonna change some stuff around since I relocated radiator to in front of core.
Mopar Performance
Re: Lets see your oil accumulator mounts! [Re: Dragula] #1276143
07/30/12 03:32 PM
07/30/12 03:32 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I still need to mount mine, or sell it...
