Offset lifters.. Whats your opinion #1275848
07/29/12 03:39 PM
07/29/12 03:39 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
After grinding the ef out of my heads, there is no way I can make my 7/16 push rods fit the RB/B1 Original combo.. Just yesterday I punched thru the intake port trying to gain that little bit of clearance I needed..
So after doing some research and talking with our friend CAB.. It sounds like the Isky Red-Zone roller lifter with the .180 intake offset is what I need to straighten this whole thing out..
However from my peabrain point of view, I would think there is too much side load on the wheel with .800 lift and 850 lbs open springs..
What's your opinion and is there any historical data to back up their reliability?
Re: Offset lifters.. Whats your opinion [Re: Jeepmon] #1275849
07/29/12 03:44 PM
07/29/12 03:44 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
at the shop I am putting my 430 together at they have several 632 chevy big blocks with the 180 offset rocker - the one just made 1350 hp with a procharger before i put mine on the pump - so i know they work.
Small block mopars have a crazy angle to the pushrods to begin with - i doubt there would actually be much side load to the lifter since it;s pretty tight in the bore - but thats just my opinion.
Re: Offset lifters.. Whats your opinion [Re: DJVCuda] #1275850
07/29/12 05:09 PM
07/29/12 05:09 PM
Finland
mafo Offline
mafo  Offline
Finland
I have had bad luck with offset lifters in 59* smallblocks, I would not do it,
in a 48* engine it works great, at least with jesel lifters
on a bigblock it should work and red zone is a great lifter
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Offset lifters.. Whats your opinion [Re: Jeepmon] #1275851
07/29/12 06:30 PM
07/29/12 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It comes down to.... you dont have a choice that I see
unless you go to a smaller diameter PR with a thicker wall
Re: Offset lifters.. Whats your opinion [Re: MR_P_BODY] #1275852
07/29/12 09:29 PM
07/29/12 09:29 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They are a necessary evil unfortunately, I got a set of the Isky Red Zone EZX lifters for my friends B1 engine. I am really not sure you're going to notice any extra wear, a lot of people will carry on about these things on internet forums but it's based solely on their opinions rather than actual accumulated data. I'd say run them and go.
Alan Jones
Re: Offset lifters.. Whats your opinion [Re: Jeepmon] #1275853
07/29/12 10:24 PM
07/29/12 10:24 PM
Washington
skrews Offline
skrews  Offline
Washington
Never seems to be a problem for BB chevy stuff, but apples to oranges you know. See if you can get the EZ Roll bearings in them, at least then if you kill a bearing it wont drop rollers through the motor.
Re: Offset lifters.. Whats your opinion [Re: skrews] #1275854
07/30/12 01:46 AM
07/30/12 01:46 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
We have several engines running with up to .210 offset pushrod cups on .904 lifters.some with 1100# plus open pressure,There have been no side loading issues at all .Also we have about 40 sets of Isky EZX bushing lifters in service and about 60 sets of Std Red Zones in service.WE did early pre release testing for Isky on the bushing lifters,This is the best product to come along in a long time,when a needle bearing fails it does hundreds of dollars of damage,The EZroll is the best Insurance you can buy for your engine.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Offset lifters.. Whats your opinion [Re: BIGSPEED] #1275855
07/30/12 02:59 AM
07/30/12 02:59 AM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
THanks everyone for the information.. I hate to show my ignorance, but when shopping for the lifters, the EZ-ROLL bushing lifters was an easy choice.. However I had no clue if I needed the offset or not and I couldnt find an answer..
So I went with the standard placement lifter thinking there was too much of a chance of damaging the lifter by placing the pushrod close to the edge..
I'll be on the phone with Isky in the morning to see how much its going to cost me to swap out the intake lifters..
They say ignorance is bliss.. well I dont feel too happy right about now.. lol Thanks again for the info..
Re: Offset lifters.. Whats your opinion [Re: Jeepmon] #1275856
07/30/12 07:46 AM
07/30/12 07:46 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use the offset lifters on big wedges engines with no problems.
Re: Offset lifters.. Whats your opinion [Re: Jeepmon] #1275857
07/30/12 08:24 AM
07/30/12 08:24 AM
gregsdart Offline
gregsdart  Offline
The offset lifter straightens the pushrod angle a bit, reducing side loads. The lifter bore keeps the lifter aligned, which keeps the load even on the roller. No problems with my setup, been using them for several years.
Re: Offset lifters.. Whats your opinion [Re: gregsdart] #1275858
07/30/12 12:59 PM
07/30/12 12:59 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
gregsdart
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Offset lifters.. Whats your opinion [Re: Jeepmon] #1275859
07/30/12 01:17 PM
07/30/12 01:17 PM
NC
440Jim Offline
440Jim  Offline
NC
One nice thing about the top of the line Comp Cams roller lifters is the pushrod seat is replaceable, so you can change the offset and the amount of pushrod oil metering.
Not trying to compare the Isky and Comp lifters, just pointing out the nice feature Comp put in their Elite Race series.
http://www.compcams.com/v002/Products/CC-'Elite%20Race'-0.aspx
Elite Race BB Chrysler offset
