cam for my 360 #1275444
07/28/12 07:30 PM
07/28/12 07:30 PM
meadville, pa
chargerbill Offline OP
meadville, pa
i am building a 1973 360. i want to put a purple cam in it nothing radical, just one bump up for stock. do i have to change the pushrods because all the purple cams i find are hydralic and the stock 360 isn't. do i have to change the lifts also i'm lost please help.
Re: cam for my 360 [Re: chargerbill] #1275445
07/28/12 07:42 PM
07/28/12 07:42 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Your 73 360 came factory with a hydraulic cam. All of the factory pushrods, rockers, and shafts will work. I had a 268/272 duration .455 lift purpleshaft in my 360 that worked great. Little rumble at idle but nothing radical. Make sure you change your valve springs to the ones that match the cam.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: cam for my 360 [Re: 71yelladustr] #1275446
07/28/12 08:36 PM
07/28/12 08:36 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have that same cam in my 340-6 in my 81 shorty. I absolutely love it. I f I was to go differene I go to the next 1 up but no bigger..
I am truckless..
Re: cam for my 360 [Re: 340SHORTY] #1275447
07/28/12 08:41 PM
07/28/12 08:41 PM
Missouri U.S.A.
Missouri U.S.A.
I also tried the next on bigger in my 360. Its a 280 duration .474 lift. Ran like hell up top but kinda killed the bottom end. Just not enough compression. Would work nice in a 10 to 1 340 though.
10.02@134
Re: cam for my 360 [Re: 71yelladustr] #1275448
07/28/12 11:25 PM
07/28/12 11:25 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
+1
It's Swifty! Swifty, you toad sucker!
Re: cam for my 360 [Re: chargerbill] #1275449
07/29/12 02:17 PM
07/29/12 02:17 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..are you sure you want an older mopar purple shaft?
.. the newer profiles are better in all aspects.
..i'd call Chase at Crane or one of the current cam manufacturers for advice like this.
Re: cam for my 360 [Re: 71yelladustr] #1275450
07/29/12 03:49 PM
07/29/12 03:49 PM
The MP 268/272 is a great all round cam for a low compression, street-driven 360, with good torque and enough power to run 12's in the quarter in a light car with headers and halfway decent gears.
Re: cam for my 360 #1275451
07/30/12 08:12 AM
07/30/12 08:12 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for a stock long block 360, a comp XE256 or XE262 is a great cam
2017 Grand Cherokee Overland
