Re: small block combos
[Re: bill8121]
#1275248
07/28/12 12:22 PM
07/28/12 12:22 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
My junk= 340 sim resto block, 360-1 heads/intake with some hand porting, 4" crank(427cu in), small solid roller 254/256* at .050 .620/660 with 1.6 rockers. 12 to 1 comp. 950hp carb on E85 1 7/8" headers to 3" exhaust to back bumper 904 trans (with some love) 9.5 converter 5000+ 8.75 rear back braced, spool, 35spline 4:10 29/13.5/15 Qtp Hoosiers Full interior/radio/ my fat butt in the seat 3375lbs
10.30s/low 10.40s at 128+ mph. high 1.30/low 1.40 60'
making some changes now on converter/trans going to a 8" and 2.45 low
"Just a Bracket car dressed up like a streetcar"
[Re: bill8121]
#1275249
07/28/12 12:51 PM
07/28/12 12:51 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
mine's a r3 440 sb, w9's by ryan, 730 roller, jesel rockers 1.65in- 1.60ex, 1050 prosystem domy, 11-1 pump gas, 904 w/low gear, 5000 stall. 9.61@138. street strip, drive anywhere.
[Re: 412 SB Duster]
#1275251
07/28/12 01:20 PM
07/28/12 01:20 PM
Triple Threat
Renton Washington
318 block 4" stroke = 390cid 11.3:1 pump gas solid cam 263/268 ported edelbrock heads victor 340 1000hp carb tti headers 904 2.74 1st gear 8" 5000 stall 27" tire 4.10 gear 3500# full of fuel and me 10.75@123
[Re: 412 SB Duster]
#1275252
07/28/12 01:21 PM
07/28/12 01:21 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
71 Duster: 360, stock crank, rods, KB 107 pistons Econo W2's, ported and flowed around 300cfm 12.25:1, 950HP, TTI 1 7/8, solid ft cam 264@ .050, engine made 560HP. 3360lbs. w/me, 8" A1 5700 conv, low gear 904, 4.56, 28"tire, dana 60, ladder bars rear, trans brake, leave on the 2 step at 4000rpm went best of 10.52@ 128mph with a 1.37 60ft. Awaiting a brand new 3G Hemi... Brian
Brian Hafliger
[Re: bill8121]
#1275255
07/28/12 11:45 PM
07/28/12 11:45 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Simple as they come:
*416 *SCAT 4.00" forged crank *SCAT I beam rods *KB Forged slug - 12.2 final CR *Bullet solid NON-roller cam (268/276 @ .050...585 net lift...106CL) *RHS iron heads (Flow 268 @ .600") *Circa 1995 Victor intake *Circa 1980 800 Holley (goes 848 on the bench) *MSD 7AL w/crank tigger
*904 (standard low gear no trans brake) *Continental/Schneider 8" converter (flashes 5200 in good air) *8.75 w spooled 4.56's *29.5 slick
At 3100#, it's given us 10.14 @ 128 in good air, 10.22 @ 126 best in Sac summer air...through the muffs...with a whole 30 degrees of timing...lol!
[Re: bill8121]
#1275256
07/29/12 06:20 AM
07/29/12 06:20 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
360 stock block BPE 4" crank Eagle H beams Wisco slugs, 12.3 W5 heads 2.08/1.60 flow 325 @ .700 Crane roller 276/284 .698/.714 net lift Harland Sharp 1.6 rockers M1 tunnel ram 2 750 Demon TR carbs 2" primary tube, 4" collector standard gear 904 Turbo Action 4200 8" T/A tranzbrake 4.86, 8.75 rear 14.5/32 4 link/strut car 2800 pounds
Has gone 9.74 @ 135 in some not so good air since being fixed, still no tuning yet 30* timing and leaving at 2000 off the foot brake.
