Temperature control cable #1274579
07/26/12 06:04 PM
07/26/12 06:04 PM
South-Central (Sebring), FL
Commando1 Offline OP
How is this clip used to attach the cable end to the door pivot pin?
Re: Temperature control cable [Re: Commando1] #1274580
07/26/12 06:15 PM
07/26/12 06:15 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
The cable goes through the two slots and the hole around the pivot arm thing.The slots face up also.Would be better if someone had a picture.
Re: Temperature control cable [Re: 71birdJ68] #1274581
07/26/12 07:23 PM
07/26/12 07:23 PM
Thanks but I'm still clueless. I guess it's going to require a pic.
Re: Temperature control cable [Re: Commando1] #1274582
07/27/12 12:33 PM
07/27/12 12:33 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Just thinking that you need to place the holder on the pin, then use pliers (gently) to pull the one side (number 3 ) in line with number 1 & 2 and then install the cable ??? The number three should hold it in place, as it wants to spring back to it's original position ????
Re: Temperature control cable [Re: a12rag] #1274583
07/27/12 03:52 PM
07/27/12 03:52 PM
Just thinking that you need to...
