99 ram 2500 pickup a/c switches to defrost under load #1274121
07/25/12 11:51 PM
07/25/12 11:51 PM
Concord Twp. Ohio
62 crown Offline OP
62 crown  Offline OP
Concord Twp. Ohio
Hi guys, I'm sure someone has already dealt with this one, but I haven't...Yet
My 99 ram's a/c blows nice and cold, until you put your foot into it, then it switches to defrost, which sucks..I thought about locking the ducts vaccum switches, but there is probably a better fix available. any suggestions ?? Thanks, Mike
62 Imperial Crown
63 Dodge 880
67 Satellite
69Roadrunner
70Roadrunner
78 Lil Red Express
81 Powerwagon
82 Grand Wagoneer
99 RAM 2500 4X4
08 RAM 2500 4X4
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: 62 crown] #1274122
07/26/12 12:07 AM
07/26/12 12:07 AM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
Look at the vac line at the firewall as it goes into the cab (plastic line pass side) I would bet it has a nice worn spot in it causing a leak.
Have had to fix this twice on my 3500.
mike
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: 62 crown] #1274123
07/26/12 02:11 AM
07/26/12 02:11 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
This was discussed last week also, IIRC. Jeep GC doing the same thing - consensus was a failed vacuum check valve. If the vac line looks okay per the previous poster's response, this may be another possible source.
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: MoparMarq] #1274124
07/26/12 01:22 PM
07/26/12 01:22 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 96' 2500 Ram does the same thing. It has done it for years. I have just dealt with it. I guess, I'll look at the vac line going into the cab as suggested. I saw a TSB before that had a diagram of which vac line needed an additional vac valve installed o cure the problem. I tried that as the diagram showed but then it stayed on defrost 100% of the time no matter where the switch was. So, I removed it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: 62 crown] #1274125
07/26/12 02:21 PM
07/26/12 02:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory says:
Vehicle Application:
1996 Dodge Ram 1500 5.2L, GAS, Vin Y, Eng Cfg V8
1999 Dodge Ram 3500 Van 5.9L, GAS, Vin Z
1998 Dodge Ram 1500 5.2L, Vin Y, Eng Cfg V8
2000 Dodge Ram 1500 Pickup 5.9L, Vin Z, Eng Cfg V8
1998 Dodge Ram 1500 5.9L, Vin Z, Eng Cfg V8
2001 Dodge Ram 1500 Pickup 5.2L, Vin Y, Eng Cfg V8
1999 Dodge Ram 1500 Van 5.2L, Vin Y, Eng Cfg V8
2001 Dodge Ram 1500 Pickup 5.9L, Vin Z, Eng Cfg V8
Customer Concern:
Driving with the A/C on under light or heavy acceleration, the airflow will stop blowing out of the vent ducts and switch to blowing out of the defrost vents.
Tests/Procedures:
1. Check the vacuum check valve at the right side of the intake manifold and check the second check valve in the line to the left of the receiver drier.
2. If they are good, check for a leaking line or defective and leaking vacuum motor in the Heater Ventilation Air Conditioning (HVAC) system.
Potential Causes:
Plastic Line
Vacuum Check Valve
Vacuum Motor
Tech Tips:
When vacuum is lost to the system as in acceleration, the HVAC system will switch to the defrost position as a safety default.
Diagnostic Codes:
None
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: John_Kunkel] #1274126
07/26/12 11:41 PM
07/26/12 11:41 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I have been trying to fix my 96 Ram 1500 for two years, I did everything listed, changed out all check valves and hoses, tested all the vac motors... no luck. I finally decided to pull out the A/C control switch, the vac lines run to it and it directs the vac to the appropriate vac motors. When I took it apart, you could see that this flat molded rubber gasket has raised ribs on it that seal the various passages so that the vac goes to the correct ports when it moves laterally. The gasket looks like it has shrunk about 10%. It also is lubricated with a grease like lubriplate and was dried out. I cleaned the surfaces and relubed it and reassembled it as a Hail Mary play. When I put in service, I ended up having to push up on the knob and stick a toothpick under it to wedge it up, but it works like a champ, no more dropping out on acceleration and my recirc setting works again which lets my A/C blow 11* colder. I called the dealer as this is a dealer only item and found that you cannot buy just the switch, you have to buy the whole panel assembly with temp setting and blower speed etc. This is about $160, so I think I will wait till winter gets here. It has worked perfectly for a couple of weeks now. Hope this helps and if you try it and it works for you, let us know!
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: Lee446] #1274127
07/28/12 11:12 AM
07/28/12 11:12 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
BTTT.
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: Lee446] #1274128
07/28/12 11:55 AM
07/28/12 11:55 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
There is a vacuum leak, and it may or may not be in the heater control system
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: gtx6970] #1274129
08/06/12 12:51 AM
08/06/12 12:51 AM
Concord Twp. Ohio
62 crown Offline OP
62 crown  Offline OP
Concord Twp. Ohio
Well, I still haven't had time to actually work on the truck, but I needed to use it this weekend, and was not willing to sweat my ass off again, so here's the way to get the A/C to blow out of the vents in the dash....Look under the dash, above the gas pedal, and you'll see the vaccum canister that controls the ducts. Hook up your Mighty Vac vaccum pump, and give it a few squeezes...and whattaya know, the vents blow cold air out again. If you need Defrost, release the vaccum pump, and out the defroster ducts it goes.
I know this is half assed, but for a quick temproairy fix, this is the way to go.... Mike
62 Imperial Crown
63 Dodge 880
67 Satellite
69Roadrunner
70Roadrunner
78 Lil Red Express
81 Powerwagon
82 Grand Wagoneer
99 RAM 2500 4X4
08 RAM 2500 4X4
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: 62 crown] #1274130
08/11/12 03:47 PM
08/11/12 03:47 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Yeah, sounds like the switch for sure. I just had the pleasure of shelling out $180 for the switch and panel, the good part is that everything works perfectly, the bad part is that a 75 cent molded rubber gate inside the switch was the only problem. Good luck!
Re: 99 ram 2500 pickup a/c switches to defrost under load [Re: Lee446] #1274131
08/11/12 05:11 PM
08/11/12 05:11 PM
Concord Twp. Ohio
62 crown Offline OP
62 crown  Offline OP
Concord Twp. Ohio
Do you think that rubber gate could be repaired ??? How about some of the liquid rubber that you dip your tool handle into....just a thought. I still haven't had a chance to get into mine yet, too many other things on the to do list...Mike
62 Imperial Crown
63 Dodge 880
67 Satellite
69Roadrunner
70Roadrunner
78 Lil Red Express
81 Powerwagon
82 Grand Wagoneer
99 RAM 2500 4X4
08 RAM 2500 4X4
