Page 3 of 3 1 2 3
Re: My first Mopar what should i do with it [Re: bboogieart] #1274061
07/26/12 07:46 PM
07/26/12 07:46 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
As said it all depends on what you want to do with it. A stroked small block is dynamite in a small package with plenty of power for the street. It also puts less weight on the front end and leaves more room in the engine bay for easier access to stuff (the headers were a joke to drop into our small-block E-body) not to mention more room in the engine bay equals more air-circulation for cooling.
Now for a drag-only car I would go big block.
Re: My first Mopar what should i do with it [Re: bboogieart] #1274062
07/27/12 07:15 AM
07/27/12 07:15 AM
Kansas City MO
Jonny Vette Offline OP
Kansas City MO
I totally agree with you guys, I was planning on driving it with the 318 till I could get all the parts together.
I wanted to get an idea of the advantages and disadvantages between the two.
And it seems that everything needs to be upgrade for either one so the cost is manly in the build.
Now I have heard the 440 can affect the handling is this true? Now I’m not planning on smashing thought turns constantly but l don’t want something that I have to fight to have fun on winding roads.
And thanks for the compliments on the car. She has a long road ahead of her to look as good as some of your guys cars but I’ll get her there.
Re: My first Mopar what should i do with it [Re: Jonny Vette] #1274063
07/27/12 07:47 AM
07/27/12 07:47 AM
minnarusta
TX9H6E4CUDA Offline
TX9H6E4CUDA  Offline
minnarusta
Read this thread and keep in mind that low compression 440s can be found for between 500 and 750 bucks pretty easy as a starting foundation. Sometimes (but not often) quite a bit less, sometimes more.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
I found a 1974 RV 440 with everything water pump, alternator etc.. with a 727 for $500 and I found a rebuilt 1980’s 360 with 727 for $450 all within a 3 hour drive
I have heard some debate over using a RV big block that there only built for torque not power. what would I need to do to make it mean and is the k member an issue?
Be careful with RV engines, make sure its a 440 and not a industrial 413 which came in alot of RV set ups
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: My first Mopar what should i do with it [Re: Jonny Vette] #1274064
07/27/12 08:04 AM
07/27/12 08:04 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Good morning Johnny V, welcome to the Board!
I'll jusst comment on the handling - you'll want to stiffen the torsion bars to at least factory specs for a BB if you go that route. If you like a tighter feel, add a front sway bar.
Other than that a BB basically handles as well as the SB in stock form. They will 'feel'different though. I drove a B-body with SB for 10 years before buying another of the same model,but with a factory BB. The BB definitely understeered more,but the more I drove it,the more I got used to the way the weight feels (Again, both cars are factory stock front-ends) and now I consider them equal in handling. But the feel of the SB is def lighter. Others may have a different opinion.
I am currently building another BB B-body more as a road car and will put a front sway bar in it, probably a thin rear swaybar too from Firm Feel.
Thanks for the interesting thread!
-Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: My first Mopar what should i do with it [Re: pa340dart] #1274065
07/28/12 05:42 AM
07/28/12 05:42 AM
salem, oregon. usa
E
elmor Offline
elmor  Offline
E
salem, oregon. usa
The 741 is greatly underestimated. I have run them behind 440's in A-bodies and B-bodies. My 67 Belvedere ran a .040 over, 10-1, 440, 452 heads with a mild bowl porting, M.P. 280 degree .474 lift cam, Weiand Action Plus intake, HP exhaust manifolds, and a 2800 stall convertor. With that small cam it had an abundance of torque. Ran 12.95 at 108 mph. 3.91 Sure-grip with 245/60-15 tires. Ran it hard at the track and on the street. Never a problem with the 741. Might have been different had I run slicks at the strip. It's STILL better than a 9 inch Ford!
Page 3 of 3 1 2 3
